Old 29-11-2019, 03:32 AM   #1
Bam
XB,XF,ZL,EA,EL,BA,SY,SZII
Bam's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Excellent write up on Air bag installation.
Default Correction of Pop-Up Glossary Definition - 'Distributor'
G'day Moderators. Can somebody please correct the pop-up glossary definition for 'Distributor'?
It currently reads; "In pre-EFI days, a distributor was a device in the ignition system of an engine that routed high voltage from the ignition coil to the spark plugs in the correct firing order."
It should read; "A distributor was a device in the ignition system of an engine that routed high voltage from the ignition coil to the spark plugs in the correct firing order."
EFI and distributors co-existed for a while. The Windsor V8 engines in the EB/ED/EF/EL Falcons had Multi Point Fuel Injection and Hall Effect / TFI distributors. I think that the last Cleveland V8 engines in the F100 ambulances also had Central Fuel Injection and distributors.
Bam is offline   Reply With Quote Multi-Quote with this Post
Old 29-11-2019, 08:46 AM   #2
russellw
Chairman & Administrator
russellw's Avatar
Default Re: Correction of Pop-Up Glossary Definition - 'Distributor'
It's been modified but with slightly different wording.
Observatio Facta Rotae
Old 29-11-2019, 12:31 PM   #3
Raptor
Raptor's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For quietly going about moderating in a fair and even manner.
An analog vs. a digital method of initiating ignition
'93 XG Falcon Ute( sold ) : '94 ED Falcon Classic ( sold ) : '04 Territory SX TS ( sold ) : '04 Falcon RTV BAII ute (still in the family)
Raptor is offline   Reply With Quote Multi-Quote with this Post
Old 29-11-2019, 09:19 PM   #4
Bam
Bam's Avatar
Thanks Russell.
Actually Raptor, I was surprised to find that my EL XR8 dizzy was in fact controlled digitally by the ECU when working normally. If there was a problem though and it stopped receiving the ECU trigger signal then it would default to analogue mode. So a bit of a hybrid then, but you could still call it a mechanical vs electrical method of routing ignition spark.
