Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > Race Brakes Sydney
Race Brakes Sydney Street and race performance pad / rotor combinations as well as brake upgrades and Exedy clutch kits. Website Link
Old 04-06-2017, 08:20 AM   #1
Terracoon Turbo
Post 6 pot Brembos on a SY mk2 Territory
I have 6 pot Brembo fronts and 4 pot rears off my old FG MK2 Falcon and want to fit them to a SY MK2 Territory. I have test fitted the front calipers only and found that it doesn't sit central on the rotor. I was wondering if there is a mounting bracket that makes the caliper sit on the rotor correctly. Also I have not fitted the rear Brembos yet but before I do, will the caliper mount correctly and sit central on the rotor?
Terracoon Turbo is offline   Reply With Quote Multi-Quote with this Post
Old 08-06-2017, 05:29 PM   #2
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Default Re: 6 pot Brembos on a SY mk2 Territory
Thanks for the message and yes we can supply he front brackets for the Terri and yes the rears will bolt up fine once you trim the backing plates..
PS. Are you the one we just sold the brackets too?
MATTHEW PEARCE
RACE BRAKES SYDNEY = When you want it to stop
Street to track is what we expertise in
Phone 02 9609 1101
sales@racebrakessydney.com.au
www.racebrakessydney.com.au
FLOORED is offline   Reply With Quote Multi-Quote with this Post
Old 08-06-2017, 06:03 PM   #3
Terracoon Turbo
Cheers. Yes it is me who just bought the brackets off you.
Old 18-06-2017, 10:16 PM   #4
dyno junkie
Also looking at fitting BF 6 and 4 piston to our TTG.
What is the cost and availability of the brackets?
2007 Silhouette Territory Turbo Ghia
11.8 seconds @ 116mph
Sold and bought back.
dyno junkie is offline   Reply With Quote Multi-Quote with this Post
Old 19-06-2017, 08:15 AM   #5
FLOORED
Race Brakes Sydney
FLOORED's Avatar
The BF caliper will technically be sitting in the wrong rotational position as the Terri calipers sit at the rear of the wheel from memory. You can swap the bleeders around with the crossover pipe but you will need new pipes made or some adapters fitted.
The Terri front brackets are $300 a pair if i can still get them.
MATTHEW PEARCE
Phone 02 9609 1101
Thread Tools
Display Modes
