Blue Power Racing Developments The home of Blue Power. Website Link |
11-05-2011, 09:14 PM | #1 | ||
What are HLA`s & are the easy to replace & what would be the cost of them each! how many are there? & would that stop my ticking noise on cold startup?
Never drive faster than your guardian angle can fly but fast enough so the devil don't catch you! |
11-05-2011, 09:26 PM | #2 | ||
Hydraulic Lash Adjusters (lifters). Could be the timing chain tensioners, the replacement of the old plastic ones will stop startup noise. The o-ring fails on the early ones causing them to bleed down and release tension on the timing chain. $250-$300 in parts, $500+ in labour.
11-05-2011, 09:31 PM | #3 | ||
Oh crap I`ve had them replaced, & It still makes the noise on startup till the motor gets warm any idea`s?
11-05-2011, 09:34 PM | #4 | ||
Is it just the 2-5 second rattle on a cold start in the morning? There are a few cases of guys replacing the HLA's at around $45 each from Ford. I would definitely get it seen to by one of our Forum Sponsor experts who have dealt with these beasts before.
11-05-2011, 09:37 PM | #5 | |||
11-05-2011, 09:53 PM | #6 | ||
are you talking about the timing chain tensioners? they make a bad rattle on start up
03 BA Pursuit Blue Power Racing Developments (03) 93053000 Ray Prescott Auto (02) 49902488
11-05-2011, 11:06 PM | #7 | |||
it`s not until you put it in gear & put a load on it till you hear the ticking noise then it goes away when the motor warms up! Iv`e tried 0w-30 & 10w-30 but it did`nt make a difference! the oil gets changed every 800km because I do stuff all kms between services, should I try 0w-40 castrol next? or will this make no difference
12-05-2011, 02:07 AM | #8 | ||
Could be a good idea to let it warm up for a few minutes before you drive it and give the oil a chance to circulate before you put a load on it...oil pressure?
12-05-2011, 02:10 AM | #9 | ||
Maybe, just maybe... you should warm it up, find a secluded area... and do a massive skid to blow out the cobwebs, lol...
12-05-2011, 12:11 PM | #10 | ||
How many HLA`s are there in the motor & are they easy to replace?
