12-10-2022, 07:34 AM | #1 | ||
My meter is a good 15 years old, it cost me $80 back then. Auto-ranging with extras of temperature, capacitance, inductance, transistor testing. I’ve barely used the last two aspects but otherwise it gets a flogging. The temperature (with k-type probe) is great for thermostat checking on the bench.
Lately it’s become increasingly unreliable when measuring DC voltage. It has long had the odd vague-out on resistance or continuity but usually twisting the dial a couple of times and/or pressing Reset, fixes this. DC volts, though, unless it’s a strong source it is no longer giving a sane reading. Technology price-points have shifted, I could replace it for $70 with a meter that does everything the same except inductance and transistor checking. Before I do that - has anyone experienced similar malfunction and resolved with a repair? |
12-10-2022, 02:51 PM | #2 | ||
Perhaps change the battery, clean the terminals with a cotton bud and isopropyl in case you have some oil or gunk in there, check the range switch too.... then bin it. If you can't trust it, you can't trust it.
Funnily enough my worst meters for reliability have been Fluke. The $50 to $150 meters seem to go forever.
I love Holdens.... |
12-10-2022, 04:19 PM | #3 | ||
Have you swapped out the leads for known reliable ones? Even a second set might give you a clue its not the meter (edit - though it looks to read non-DC without issue)
12-10-2022, 06:39 PM | #4 | ||
Have you opened it up and:
Checked for dry joins especially around where the sockets for the test lead are solder to the PCB; Checked the tracks of the selection knob are making good contacts with the knob and are not worn away; The batteries have not leaked and corroded anything; and there are no smoke marks or other indications of component failure?
regards Blue |
12-10-2022, 08:51 PM | #5 | ||
Have pulled it down and visually checked.
All solder joints look fine. Processor has black epoxy security, this does not seem to be chemically decomposing. The double-ball dial detent has been weeping grease onto the circuit board, possibly contaminating the wipers and their tracks. I lightly buffed the wipers with grey Scotchbrite, thoroughly cleaned them and the tracks with wax-and-grease remover, cleaned the LCD signal contacts with alcohol, reassembled. Just another evening of stuff you do when TV isn’t in your life… Now to test it! |
13-10-2022, 12:13 AM | #6 | ||
Well, it’s definitely no worse. I really need daylight to confirm - but it may be fixed.
2 users like this post: |
13-10-2022, 12:58 AM | #7 | ||
Looking for clues...
I have a Digitech meter that doesn’t read DC volts at all now. Luckily I have replaced it with one that does more, like reading frequency. I’m not sure what to do with the faulty meter… label it AC only? Or for continuity checks , and AC if you dare. Either way I might make a DODGY label for it.
Swanny’s Fundraiser for the 2024 MS Brissie to the Bay Bike Ride 2016 Ford Falcon FG/X XR6 Turbo you beaut ute 1985 XR4Ti Sierra - Build Thread 1971 Fairlane 500 and... a collection of Jeep Towpigs and... two collections of rust and some new plastic bits roughly shaped like an F-Truck and.... some spare metal bits with holes in them |
13-10-2022, 05:18 AM | #8 | ||
13-10-2022, 06:27 PM | #9 | ||
Experienced Member
Why would you bother with it, bin it and get a quality replacement.
13-10-2022, 11:40 PM | #10 | ||
I’m pretty tight with some things. It doesn’t provide data which directly affects health and safety items, the most common use is continuity/resistance followed by DC volts. So, if it’s been scrubbed up sufficiently to rely on for these tasks - I’ll save my $69 for now.
14-10-2022, 03:20 PM | #11 | |||
Experienced Member
Cheers |
16-10-2022, 08:02 PM | #12 | ||
BANNED
Digitech? .... am surprised it lasted this long....
Please press the "Like" button if you enjoy my posts. (It's the red triangle with exclamation mark on the left) |
