Old 07-01-2024, 03:36 PM   #1
Reaper8
Reaper8's Avatar
Default power window switch
Hi all have had nothing but problems with my windows since ive had the car. new switches, new motors and had enough. has anyone done a switch change to something like a set of fg switches ect.
Reaper8 is offline   Reply With Quote Multi-Quote with this Post
Old 12-02-2024, 10:24 PM   #2
TICKXR
Question Re: power window switch
Hi All, strange issue with au ute power window.
Passenger side window works fine unless it is opened fully , then it will stop and nothing will make it move and go back up.
Pretty sure motor, switches, fuses etc not at fault because it I leave it come
try again the next day , window goes up and works fine , as long as I dont go
full down .
Seems like after at least 12 hrs is needed and all back to normal??
Any ideas appreciated
TICKXR is offline   Reply With Quote Multi-Quote with this Post
Old 12-02-2024, 10:56 PM   #3
mad2
Regular...with metamusal
Default Re: power window switch
full down .
Hi. possibly the switch/es have a heap of carbon in them causing the issues?. they need to be cleaned & some carbon grease [? i think that's what it's called] applied to contacts [i never did it to the AU and havn't yet needed to with the BA/BF]. also the glass binding when going up/down can cause some issues. and yes i had issues in 'Ol yella [AU wagooon] with the switches.
mad2 is online now   Reply With Quote Multi-Quote with this Post
Old 12-02-2024, 11:45 PM   #4
T3rminator
T3rminator's Avatar
My driver switch was playing up, unresponsive sometimes, then responsive again.
On a hunch, I removed all the pins from the connector socket, sprayed them with electronics parts cleaner, put them back in (make sure you remember which pin goes where!!...taking a photo helps), and the problem was fixed.
If you suspect its the switch itself, you can get them from ebay for like under $20. I've had 2 cheapies from ebay and they work fine.
Forget trying to open them up and clean the inside....I tried that once and all these little pieces fell on my lap, and I had no idea how to put them all back. :P
If you know what you are doing, you could try put them back. I couldn't get the buttons to click up or down no matter how I put them back!
Rides (past and present)
T3rminator is online now   Reply With Quote Multi-Quote with this Post
Old 13-02-2024, 09:26 PM   #5
mad2
try the AU ones.......
Old 13-02-2024, 10:25 PM   #6
T3rminator
T3rminator's Avatar
AU switch housing looks different. How would you get them to sit on the BA door handle?
Old 14-02-2024, 03:16 PM   #7
mad2
on this page we are talking AU not BA/BF
Old 14-02-2024, 03:44 PM   #8
T3rminator
T3rminator's Avatar
Woops. Sorry OP. I completely missed the section. Definitely go with AU for AU switch
Old 15-02-2024, 04:14 PM   #9
chinamonty
with AU window switches (not the main controller) they are fairly easy to fix. The problem they have is the nylon actuator wears. If this happens then just put a bad of model cement in the metal contact so it is built up a little. Otherwise just buy new ones - they are not expensive. I keep a rebuilt one in the glovebox for emergencies.
chinamonty is offline   Reply With Quote Multi-Quote with this Post
Old 15-02-2024, 06:31 PM   #10
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
AU's can fix anything
Old 15-02-2024, 08:08 PM   #11
chinamonty
Its not hard to put them in place. they pivot on the H brass part that sticks up from the pcb. The ends then have to touch the round silver pads so that gives you the orientation.
