Go Back   Australian Ford Forums > General Topics > Non Ford Related Community Forums > Project Builds (non Car)
Project Builds (non Car) Here is an area where you can show / discuss other non car builds be they bikes, caravans, boats, BBQ's or whatever.
Old 02-02-2023, 09:11 PM   #31
prktkljokr
praek tih kl jo kr
prktkljokr's Avatar
Default Re: Car trailer build
Update on the trailer, it has done a few pick ups, a couple of country runs and some of it was off road so its now pretty chipped up and scratched, but has proven to be exactly what I needed, it looks like its 10 years old with red dust and peeling paint now, might have to do a freshen up already
I Picked a few auction cars up, did a run to Busselton with it to pick up a late model Mini wagon I purchased through an online auction (good buy ), then a run to Geraldton to pick up a Garlic harvester and take it through to Gin Gin, this is where it copped the stone chips all over and the red dust, I have 1 noisy bearing already and the voltage meter on the control box copped a decent rock, so a few little repairs to be done, but overall doing what I intended it to do.
prktkljokr is online now   Reply With Quote Multi-Quote with this Post
Old 01-03-2023, 11:57 AM   #32
Buggersmuddle
Once it was built and finished, what was the process to get it registered? Did you have to get it engineer inspected and then pit tested?
What did the process cost, apart from the cost of the build itself?
What do they base the capacity rating on? Axel size? , brakes on one or both axels? Hitch rating? Frame tube dimensions? Tyre rating? Anything else?
Also in sw wa and looking at building something similar.
Any tips on finding a good caravan donor? All the ones I've looked at were pretty light weight frames and id be better off starting from scratch i think.
Which auction did you find that one?
Apologies for the interrogation!
Holla if you're south sometime, ill swing ya a beer!!
Buggersmuddle is offline   Reply With Quote Multi-Quote with this Post
Old 01-03-2023, 08:32 PM   #33
prktkljokr
praek tih kl jo kr
prktkljokr's Avatar
On my way out at the moment when I get home I will give you a quick run down of what I did.
This VSB will help you when you go to build 1
https://www.infrastructure.gov.au/si...6-20210222.pdf
Old 02-03-2023, 01:10 AM   #34
prktkljokr
praek tih kl jo kr
prktkljokr's Avatar
Once it was finished I just applied for a VIN, took it to a registered weigh bridge and paid for a certificate of Tare weight, applied all the details to the vin tag and it was ready for licence.
No engineer needed.
The cost once made was just the weigh bridge certificate, pit inspection then licence fees.
I know with my trailer it has 10" electric drums, so the max weight was 3000KG, if I had 12" electric drums it would have been 4500KG, the axles have parallel bearings, the tyres have a 1500kg load rating each and the leaf spring set up was rated to 1500kg per spring, it was just the brake drums that let me down.
They can base the maximum weight on axle type, spring rates and what tyre you use, so you cant just put a set of car tyres on it as they would not have a decent load rating, plus when you register the trailer they will ask for the specs of the components used ( brake spec, leaf spring spec braking capacity etc), worth having a talk to whoever will be licencing it in the end as they can give you the necessary paperwork for this.
Donor caravans don't come up that often and when they do its luck of the draw what they go for, the auction I use is one that I used to use for buying stock for my wrecking yard, so it was a Dealer only auction site, and as I am still registered, I still buy from them quite regularly, they are a Australia wide auction site, I was just on at the right time when this one came up, I didn't need it at the time but couldn't let it go at that price.
You would be better off building from scratch if you can, then you can make it suit what you need, this one just ticked the boxes of what I wanted, it wasn't planned, I purchased the caravan for the parts to make my slide on camper, the car trailer was just a bonus.
You can apply for a W.A. trailer VIN here.
https://www.wa.gov.au/service/transp...ication-number
