Go Back   Australian Ford Forums > Club and Speciality Forums > Ford Car Clubs > Early Falcon Car Club of Qld Inc
Early Falcon Car Club of Qld Inc The Queensland early model Falcon Club.
Old 21-04-2010, 12:55 PM   #1
marrog007
Red face old falcon with two shock tower numbers
I have a XT Fairmont, and was interested in its origins only to find two shock tower numbers but with one set crossed out with what looks like a row of XX's through it. The one you can read (just) ,does not correspond with the little plate numbers (prefix,serial,sido,model) ,nor does the numbers crossed out. Its a 1968,JG34HL, so i have looked up all these details ,but why would the numbers on the tower not only not match but one set of numbers be crossed out , I am its 3rd owner, last old guy had it shed bound for the last 30 years. Any ideas??Margaret
marrog007 is offline   Reply With Quote Multi-Quote with this Post
Old 21-04-2010, 01:11 PM   #2
Trevor 57
is now there
Trevor 57's Avatar
In the XP (1966) I own, the shock tower number is the original engine number, maybe the car has had the engine replaced and they have re-stamped the new number.
Interestingly, Vicroads will not use the original VIN from the car as the VIN for registration purposes, they use that shock tower number.
The reason? The VIN on the XP is on the piece of steel in front of the radiator, the ID plates are held on by self tappers in the same place and is easily replaced by car re-branders. The shock tower is not so easy to replace
I reserve the right to arm bears
Trevor 57 is online now   Reply With Quote Multi-Quote with this Post
Old 05-09-2011, 09:36 PM   #3
XT UTE 68
GIVIT Rally 84 BARRA XE
XT UTE 68's Avatar
Default Re: old falcon with two shock tower numbers
On the XT's there were 2 sets of numbers,
The VIN starting with JG or JH is on the radiator panel.
The Engine Number was stamped on the shockie tower and the engine. If the original engine is still in place they should match, but will differ from the VIN.
XT BF2 SZ BA
XG E Outback Ute
XE BARRA - http://www.fordforums.com.au/showthread.php?t=11382891 - 2007 GER Via Birdsville, 2008 via Broken Hill, 2009 via Cape York, 2012 via Karumba, 2014 via Innamincka, 2016 GIVIT RBR, 2017 via Boulia, 2018 Via Mighty Murray, 2019 Via Dig Tree, 2020 Via Thargomindah, 2021 Via Lawn Hill Gorge, 2023 Westmar - Gunnedah
Sponsors, London Fire & Safe www.fireextinguisher-and-safes.com, G&D exhausts and suspension Beenleigh , Beenleigh Bob Jane
XT UTE 68 is offline   Reply With Quote Multi-Quote with this Post
Old 04-01-2013, 09:36 AM   #4
i78power
xp futura hardtop
I'm a bit vague on this but I remember owning a car in Nsw with a vin number crossed out with x's and a new number stamped.I was led to believe by the rta that this was done to rebirthed cars that were recovered by police. Maybe you could look into this further as I'm not 100% its correct
i78power is offline   Reply With Quote Multi-Quote with this Post
Old 04-01-2013, 10:58 AM   #5
Landau Stable
Landau Tragic
Landau Stable's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: For his many posts on welding and fabricating for coupes
Probably a factory stuff up, and they just redid them. Was one of the last letters of the crossed out numbers ending with an R?
STOLEN Cosmic blue Landau. Engine and Vin no: JG70PU12931K. Please pm me if you have any info
Landau Stable is offline   Reply With Quote Multi-Quote with this Post
