Old 01-09-2012, 01:22 PM   #1
burkie_21
wild xr8
burkie_21's Avatar
Default NL electrics into xr
Just bought an NL Fairlane and am going to swap all the leather, elec windows, woodgrain and chrome goodies into the xr and was wondering if anyone has put the climate control modules in? would i need to change heater box and all the dash assembly or is it as easy as pullin old standard one out and plugging new one in? would i need to change bcm or anything over to run the electric windows?
cheers
burkie
burkie_21 is offline   Reply With Quote Multi-Quote with this Post
Old 01-09-2012, 05:45 PM   #2
my67xr
my67xr's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: This contribution: 04 SX TX AWD, drama's replacing upper outer joints w/Nolathane replacements
Default Re: NL electrics into xr
it will require the dash to come out, and swap a blend door motor into your heaterbox, take out the old cable operated one.
the sensor/thermostat module is different, behind the glovebox.
and the dash loom is different too
fitting the NL loom will also require a few more mods to work with the EL dash instruments, the plugs are different.
if yopu can, use an EL Fairmont dash loom.
im not sure if there's a tech document on the conversion here?
it can take around 6 hours doing it the first time...
there is a technical document on Fordmods for this.
Money Talks, but all i ever hear is it saying Goodbye!!
click below to view my build threads
67 XR Fairmont
04 SX TX Territory AWD
my67xr is offline   Reply With Quote Multi-Quote with this Post
Old 01-09-2012, 07:11 PM   #3
wodahs
wodahs's Avatar
and the fire wall is different so you will have to cut that out and weld in the one from the nl to mount the heater box , also think the plumbing is in a different area
yes still (as money n time permit) doing the
rebuilding the zh fairlane with a clevo 400m 4v heads injected whipple blown with aode 4 speed trans to a 9" ....... we'll get there eventually
just remember don't be afraid to try something new.
Remember, amateurs built the Ark...Professionals built the Titanic!
I have taken up meditation... at least it's better than sitting around doing nothing !!
wodahs is offline   Reply With Quote Multi-Quote with this Post
Old 01-09-2012, 07:11 PM   #4
Alby1
you'd be popular too
Alby1's Avatar
I put a tech doc for fairmont to XR but does not include climate control, as my67xr said(same guy who helped me) fairmont loom plugs straight in for windows
98 EL XR8II Manual
E303 cam, ported gt40p heads, 1.7 rockers, high flow cats, Au220 TB, 70mm Maf, tune (215rwkw) and some bigger brakes
Have now brought my car to the 2000's with electric rear windows, door lights and wood trims
Alby1 is offline   Reply With Quote Multi-Quote with this Post
Old 01-09-2012, 08:35 PM   #5
wodahs
wodahs's Avatar
disregard sorry had a moment
mind went straight to thinking sixtys model xr (doing a custom job) not veriant xr(6/8)
Old 02-09-2012, 11:33 AM   #6
burkie_21
wild xr8
burkie_21's Avatar
so if i get a fairmont dash loom a should be pretty right?
Old 02-09-2012, 02:52 PM   #7
my67xr
my67xr's Avatar
yep, get a complete EL Fairmont dash loom .
an EF Fairmont one is different, (connections for bem etc)
67 XR Fairmont
Old 02-09-2012, 07:33 PM   #8
burkie_21
wild xr8
burkie_21's Avatar
would i need to swap the bcm or keep the original xr one??
Old 03-09-2012, 09:34 PM   #9
burkie_21
wild xr8
burkie_21's Avatar
This is the interior i got
Old 04-09-2012, 06:35 PM   #10
Bossxr8
Peter Car
Bossxr8's Avatar
I'll swap you my drivers seat for yours
Mines looking a little shabby, that one looks in excellent nick.
