Old 14-04-2020, 08:08 AM   #1
ul9601
Default tips for a new player pls?
Hi all,
Looking to buy an AU, specifically AUII or III for obvious reasons (even though AU Forte is a thing of a beauty ;))
Apparently they rust real bad? Any pointers to the locations to look out for?
There is this SVP I want to look at, as V8s are far pricier (for some reason) compared to XR6 - tips on drivetrain wise?
ul9601 is offline   Reply With Quote Multi-Quote with this Post
Old 14-04-2020, 11:10 AM   #2
mchaggis
mchaggis's Avatar
Default Re: tips for a new player pls?
Originally Posted by ul9601 View Post
Hi all,
With my project I found rust in quite a few places:
  • Under the roof rubbers
  • Under the trim below the windscreen in engine bay (near compliance plates)
  • Boot gas strut lugs
  • front and rear window seals
  • lower boot lid
  • under the trail lights
Actually there was rust everywhere, some easy to fix some a little more serious.
Just have a good poke around.
The Current Fleet:
2018 Kia Sportage GTLine
2014 FG-X G6E T
2012 FG-II GTP #288
2002 AU-III XR8
(1977 TE Cortina, 2001 AUII XR6, 2004 BAI XR8 Ute, 2005 BAII Typhoon, 2008 FG F6, 2015 FG-X XR6 Ute, 2006 SY Territory Turbo Ghia...it just used too much fuel)
mchaggis is offline   Reply With Quote Multi-Quote with this Post
Old 14-04-2020, 11:22 AM   #3
ul9601
Thanks - is the car from moisty part of the country or do they just rust regardless?
Old 14-04-2020, 07:26 PM   #4
mchaggis
mchaggis's Avatar
Mine was a WA car, but I think they're prone to rusting.
The Current Fleet:
2014 FG-X G6E T
2012 FG-II GTP #288
2002 AU-III XR8
Old 14-04-2020, 07:35 PM   #5
PG2
#neuteredlyfe
PG2's Avatar
Mine is a 2001 AUII and is pretty much rust free. I've had the tail lights out and to my surprise there was no rust under there as well.
My AUII ute has one spot of rust in it - under the driver's scuff plate. The AUIII wagon I have has two spots in the gutter but that is from the roof racks that it had fitted when I bought it.
Keep in mind that they are now 20 odd years old and will have some rust hidden somewhere. Look in all of the spots that mchaggis listed and are most of the way there.
PG2 is online now   Reply With Quote Multi-Quote with this Post
Old 14-04-2020, 08:30 PM   #6
Ben
Ben's Avatar
Had a small amount behind my RH taillight and under battery. Also on my 2nd rusty boot lid...
2001 AU2 220 XR8 - Build thread
Ben is offline   Reply With Quote Multi-Quote with this Post
Old 15-04-2020, 04:28 PM   #7
ul9601
thanks - i suppose some of the area like the tail lights you really cant check after buying it and pulling apart?
Old 15-04-2020, 05:05 PM   #8
PG2
#neuteredlyfe
PG2's Avatar
Pull back the boot lining behind the tail lights and look at the seam being the tail lights. While not a 100% foolproof if there is rust along that seam there will be more rust under the tail lights.
Otherwise, ask if you can take the tail lights out to look. It is only two screws and a 10mm nut. It takes 30 seconds. The worst thing the owner can say is no.
Old 15-04-2020, 05:25 PM   #9
Cav
HUGH JARSE
Cav's Avatar
Check the recesses in the boot near where the struts attach to the body.
Cav is offline   Reply With Quote Multi-Quote with this Post
