19-04-2024, 05:00 PM | #1 | ||
Hi all,
I was driving our Mondeo yesterday when it started shuddering. My thoughts were the gearbox crapped itself so I put it in neutral to roll off the road and straight away it stalled. NRMA towed it to a safe place and then a guy came out and didn’t know what was wrong. I had a mobile mechanic come out this morning and checked it out and he said it looks like an electrical fault. He had me take pics of his device he connected up which shows all the faults. Had 3 pages first up then he cleared them and tried starting it again and only one fault. I’ve included the images of the faults. Any ideas of what’s wrong? Car has 250,000kms and we have been thinking of upgrading so I really don’t want to spend thousands repairing it. Any ideas on what the likely issue is? |
20-04-2024, 10:31 PM | #2 | ||
What was the one fault code after he cleared the three pages of faults and tried starting it? Is that your image0.jpeg?
Through FORScan I've seen an assortment of DTCs present at various times in my car for BCM, mirrors and so forth, much like you have in your other images. The car is operating fine so I assume those are just temporary glitches occurring from time to time. So I think we can probably discount most of those if they were preexisting. |
22-04-2024, 11:50 AM | #3 | ||
22-04-2024, 11:30 PM | #4 | |||
In image0, U3001:00-08 is associated with the ABS module and the description "improper shutdown" is caused probably from loss of power, so I think this is a symptom and not the culprit.
Searching the internet for more information on that code, lo and behold one of the top results came back to this site. Cobrin had what sounds like exactly the same issue: diesel MB stalled and DTCs including ABS U3001:00-08, and PCM P0335:38-28 for a fault with the Crankshaft Position Sensor (CKP Sensor or CKPS). He's replaced the CKP sensor and the car ran again. See: Stalled MB TDCi this time looks like I've got it Now I'm looking through your initial fault codes for DTCs from the PCM and in image2 I see you've got a P0341:31-6C for Camshaft Position Sensor fault. It seems possible that your camshaft position sensor (CMP sensor) might be faulty and need replacement in the same manner that Cobrin needed to replace his CKP sensor. Or, it might be some other issue related to the timing of the engine. I've done some more Googling but haven't found a slam-dunk answer relating to a Mondeo. I'll have to ponder it some more, in the mean time here's an explanatory article I found that may be helpful: https://www.carparts.com/blog/p0341-...single-sensor/ Quote:
23-04-2024, 02:00 PM | #5 | ||
Thanks for the detailed response.
I’ve spoken to the two local ford dealers and the earliest they can look at it is 7th of May so I’m thinking I’ll try replace the Camshaft sensor myself. Anyone got a pic of its exact location? |
24-04-2024, 09:34 PM | #6 | ||
Found it. Ordered one and should arrive by Friday. Fingers crossed this is the problem.
25-04-2024, 12:14 AM | #7 | ||
The sensors are quite durable.
From memory these are a “slip and grip” crank sprocket for the timing belt. If the crank (flywheel actually) wasn’t pinned last belt change, but timed up by matching texta marks, you can be out enough to set the cam sensor code. Also winding the engine backwards can affect valve timing in some cars, I think this motor is included. If the belt is broken you possibly just need new rockers to fix the problem. |
25-04-2024, 01:56 AM | #8 | |||
I agree with Citroënbender that although the DTC describes an problem with the data coming from the sensor, it's just as likely the sensor itself is functioning properly and the cause is something other. By all means you may check and change the sensor but you'll need to look to other factors in the event it's not the sensor. Case in point, here's another Alan Howatt video about a no-start concern that seems like a fuel pump fault, but turns out to be an unusual mechanical failure of the camshaft: If you are going to attempt to work on the car yourself you should really get yourself an OBD scanner tool and the FORScan software (which you can get on Windows, Android or iOS). This will be necessary to read any fault codes to help you work out where issues occur as well as inspect live data and perform service procedures. You should look for an OBD tool that can interrogate both HS-CAN and MS-CAN networks for Ford vehicles. I personally use an OBDLink MX wireless dongle which is Bluetooth connected to my Android phone running FORScan. I've found a few forum threads of other owners troubleshooting similar issues and fault codes. They might be worth reading to see if there's any similarities with your experience. Unfortunately most of these do not have a definitive answer where the OP provides a final post saying how they fixed it.
2011 Mondeo MC Titanium TDCi wagon, Panther Black - new Powershift sensor: Nov 2016 Last edited by Mondaveo; 25-04-2024 at 02:01 AM. |
25-04-2024, 09:35 AM | #9 | ||
Being 2009 I think it’s a DW10 type motor.
They have a problem for the unfamiliar with the link chain (timing the exhaust cam off the belt driven intake cam) being hydraulically tensioned - with no oil pressure, if you wind the motor backwards it can mistime the exhaust cam. For correct timing belt replacement you need to pin the flywheel and inlet cam, plus physically lock the ring gear with a suitable gripper to allow the correct torque to be reached when re-tightening the crank sprocket. The flywheel pin alone is only five or six mm and will shear. One really good thing about the design of these motors as I touched on before, is the rocker arms are like fuses, they fail as protection. A belt failure will almost always result in rocker arm carnage, but no broken cams or cam caps or flatted big-ends. Sump off to remove the shrapnel, clean up and replace the rockers, time the link chain correctly, reseal the motor and fit a new belt. Hydraulicking is a different fault and one I’ve not seen personally. Gut feeling says the crank and head would survive, with biggest risk to be bore damage. |
25-04-2024, 07:16 PM | #10 | ||
Thanks all, I’m really only replacing the Camshaft sensor as a hope to solve it so I’m not waiting until the 7th of May so Ford can look at it. Had they been able to look at it now I wouldn’t have bothered.
05-05-2024, 12:08 AM | #11 | ||
Was there a resolution to this problem?
05-05-2024, 12:02 PM | #12 | ||
05-05-2024, 12:53 PM | #13 | ||
So you tried a different sensor as intended, no change?
05-05-2024, 01:31 PM | #14 | ||
Sorry, I thought I posted that. Yes I replaced the sensor but no luck.
I've fully charged the battery last night and just.put it back in the car ready for Tuesday. Tried cranking it over again and it wanted to start a few times with the higher cranking of the fully charged battery but could quite get there. Will see how it goes on Tuesday with Ford. |
