22-06-2012, 07:43 PM | #31 | ||
You blokes are champions. Just bought a new (to me) AUII XR8 ute and none of the remotes were working, even with new batteries.
Got replacements, no instructions. Come to these forums and all sorted, cheers. |
12-07-2012, 10:23 PM | #32 | ||
I have the 4 button remote and I reprogrammed it but the unlock button doesn't work anyany more. All the other buttons work fine. I tried reprogramming it a few times but this always happens. Any advice?
12-07-2012, 10:51 PM | #33 | ||
maybe dry solder joint
12-07-2012, 11:14 PM | #34 | ||
take the remote apart and have alook im guessing the button has rusted apart due to the glue **** that comes out of it
02-09-2012, 08:40 PM | #35 | ||
hi everyone, I have a question, i have tried to follow the steps in this thread to program my new remote, i press the demister button 3 times quickly with the key turned to both position before starting and i can not get my AU falcon futura to enter learn mode. if anybody out there has had the same problem could you let me know how to fix this problem im having. cheers
02-09-2012, 08:44 PM | #36 | ||
I had to use an original remote to start the reprogramming sequence.
Fords the family have owned: Model T, Model A, Fordson truck, 105E Anglias, MkI Escorts, MkI Cortinas, MkII Cortina, Zephyr Six, ZC Fairlane, AUII Ute manual, BA XT sedan, Territory TS SZ RWD. |
02-09-2012, 09:06 PM | #37 | ||
the door button on the remote that is programed will not work, so ineed to program a new one to lock and unlock the doors but the boot still opens with the button...
also should there be a smart lock light flashing somewhere on the dash??? |
02-09-2012, 10:33 PM | #38 | ||
Do u have smart lock series 1 or series 2/3 which is diffrent
03-09-2012, 11:24 AM | #39 | ||
Its series 1
07-05-2013, 10:33 PM | #40 | ||
hi all,
followed the procedures above and now I have two key pads programmed thanks for the tips Regards John |
02-09-2013, 02:51 PM | #41 | ||
If you go accessories and then hit demister within the three sec as said wait then the doors will lock and then hit the remote lock and unlock ( both if needed ) then turn car off that's it guys not really hard ( for two three and four button )
01-08-2016, 10:55 PM | #42 | ||
Hey Everone.
I have A 98 AU1 Fairmont With Smart Lock. My Question Is... Will EF,EL, Ignition Lock + Barrel Interchange (Bolt Up) With Early AU1? My Way Of Thinking Is Yes...Seeings There Both Smart Lock... Thought I'd Just Run It Past Some Experts 2 Be Sure. Thanks In Advance. John. |
03-08-2016, 09:31 PM | #43 | ||
Spanner Thrower
Remotes will, but the key is also chipped so you'd have to get it programmed to the au's bcm
1999 AU Futura Wagon (Nickname Betsie the Barge-***) Current Mods: Fairmont Cluster, LED's Changed to Purple, Lukey Competition Extractors, 2.5" Hi flow Cat, Hi-Stall Converter, ED Box with FG internals, AUIII VCT Fuel Rail + Injectors, F6 Fuel Regulator, Stereo upgrade, Aftermarket LPG. Awaiting Wife Approval Mods: TE50 Front Bar, AU Tickford/SR Interior, Roof Racks, Slimline Weathershields, 2.5" Cat Back Exhaust, 27mm Front Sway Bar, Other Shiny things! |
03-08-2016, 09:49 PM | #44 | ||
Hi. The AU didnt get a chipped key till series 2, series 1 can use any key. Cheers MD
HI I'M MICHAEL 2003 ACID RUSH BA FUTURA WAGON light up window switches | auto on cruise control | doubleclick window lift from remote |
05-02-2018, 06:54 PM | #45 | ||
Hello everyone, I am having a problem with my remote I have a series 2 au ghia the remote makes the indicator lights come on as usual but thats it it wont lock or unlock the doors just nothing . I have changed the battery to no availI tried reprograming it but interestingly I got no response at all in regards to the doors cycling also the the door lock button on the dash wont respond either does anybody have any ideas where to look for the problem ,.... Thanks Steve
05-02-2018, 09:08 PM | #46 | ||
🚫⏰4️⃣🐃💩
Hold the door lock button on the dash for 2 seconds. Does that work?
05-02-2018, 09:12 PM | #47 | ||
Hi mate , Thanks so much for getting back to me I have it sorted it was as simple as the door lock fuse in the cabin fuse box lol Thanks again regards steve
20-10-2018, 10:22 AM | #48 | ||
My first post, so take it gentle
Programming Ford AU2 Ute Remotes This is how I succeeded. Using and combining all I could find on the net Disconnect battery and leave overnight, 1-2 hours could be ok Connect battery The SECRET. Ute interior light must be working and the light switch in the position that switches the light on when the door is opened ????? Ask MR Ford. This was the step that stuffed me and is needed to go into learning mode. 1. Then sit in car with door closed ,open and close the door, interior light will come on. 2. Turn the ignition to the ACC position and press the rear demist button 3 times, within 5 seconds. 3. You then press a button on the first remote to be trained , the door locks will cycle. 4. Then press a button on the 2nd to be trained and the door locks will cycle again. 5. Repeat this step for the the rest of the remotes to be trained to the car. 6. The first keypad trained will result in one door lock cycle, the second will result in 2 door lock cycles, and so on. CHEERS BILL J |
20-10-2018, 06:57 PM | #49 | ||
Next upgraded Mk1 Leopard
Welcome Bill, sharing is what our Forum is about.
UK
02-09-2020, 02:25 AM | #50 | ||
I've got a 98 AUI wagon amd got a single button remote, as I was told that is the one for a wagon.
I went to programme it, the locks cycled, hit the button on the remote and got nothing. Hit it again and still nothing. Removed the key and tried again from the start. Kept trying this I was ready to hit the dash 3 times within 5 seconds.... Cheers in advance. Turned the car off, removed the key amd tried the process again, but this time, I couldn't get the locks to cycle
CURRENT FORDS 1997 5.0 DL LTD Sedan 1998 4.0 AU S1 Forte Wagon PREVIOUS FORDS ZA/B/C/D Fairlaine Sedans 1979 2.0 MKII Escort Coupe 2000 4.0 AUII Forte Sedan
