Old 21-07-2019, 12:15 PM   #1
MrDavo69
Default Tool for removing the sump plug on my Mondeo 2010 MB TDCi?
Hi All,
I have a Ford Mondeo 2010 MB TDCi 2.0 Litre.
I'm now trying to change the oil. However it is proving difficult to find the correct tool to remove the sump plug.
I tried a T50 (hex) tool, but that stripped the plug slightly (as shown below).
https://yadi.sk/i/u9ZzJB4s9rJymA
Can anyone please tell what tool I need to remove this plug?
Also does anyone know what thread size the sump plug is?
I ideally want to replace the one that I currently have with a standard bolt.
Any help will be really appreciated.
Kind Regards,
Davo
MrDavo69 is offline   Reply With Quote Multi-Quote with this Post
Old 22-07-2019, 09:36 AM   #2
russellw
Chairman & Administrator
russellw's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: Raptor: For Continued, and prolonged service to the wider Ford Community Technical Contributor: For members who share their technical expertise. - Issue reason: Adrenaline: Russell's outstanding management and contributions to the technical resources portal of the forum, in addition to valuable technical contributions made in all other areas of the forum. Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Falcon Coupe: For being the driving force behind everything here. Countless hours behind the scenes working to make AFF the great place it is.
Default Re: Tool for removing the sump plug on my Mondeo 2010 MB TDCi?
The sump plug is an M14x1.25 and I believe the fitting is actually an H8 size (8mm hex key).
Observatio Facta Rotae
Old 22-07-2019, 01:22 PM   #3
NZ XR6
Yes, definitely hex and not Torx. I would suggest a hex socket to remove it, not a L shaped key.
I'm not sure a normal bolt will work as the drain hole is slightly recessed.
Good luck.
NZ XR6 is offline   Reply With Quote Multi-Quote with this Post
Old 22-07-2019, 03:01 PM   #4
These https://www.supercheapauto.com.au/p/...es/326049.html
aussiblue is online now   Reply With Quote Multi-Quote with this Post
Old 24-07-2019, 09:43 PM   #5
cobrin
Challenge Accepted!
cobrin's Avatar
cold chisel is what I used on mine from the damage Darra Ford did to the poor vehicle over the years (amongst other lazy sh*t they did). Couple of taps around the edge saw it start to move and come free. I replaced it with a different plug and thought about a smart-0-seal plug but couldn't be bothered in the end.
It's been crossed threaded (see what I'm saying Darra Ford) and is still hanging in there cause it's only a plug and doesn't need a breaker bar to be 'done up'. /end rant
2009 MB Mondeo Zetec TDCI
Thread Tools
Display Modes
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
