Old 26-07-2017, 09:59 AM   #181
XB GS 351 Coupe
Default Re: Photobucket... WTF!!
I was using Photobucket as that is what I was told I need to use on this forum, I am part of other forums and I can upload photos straight from my computer to any posts without any need for a hosting web site.
Why can't this forum be the same??
The Daily Driver : '98 EL Falcon, 5 Speed , 3.45 lsd
The Week End Bruiser : FPV BF GT 40th Anniversary, 6 Speed Manual, 6/4 Brembo and lots of Herrod goodies
Project 1 : '75 XB GS 351 Ute, Toploader, 9" with 3.5's
Project 2 : '74 XB GS Big Block Coupe, Toploader, 9" with 4.11's
In Storage : '74 XB GS 351 Fairmont Sedan
XB Falcon Owners Group
Mike's Man Cave
XB GS 351 Coupe is offline   Reply With Quote Multi-Quote with this Post
Old 26-07-2017, 10:03 AM   #182
PG2
#neuteredlyfe
PG2's Avatar
I believe that Russ is looking into a few options that will allow users to upload onto the Forum.
Give Russ and the admin a little time to sort this out. As with everyone who is affected by photobucket's decision, I assume it has caught Russ and the admin team out by surprise as well.
Old 26-07-2017, 11:20 AM   #183
PridenJoy
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For his contributions to the forum, especially showcased with his highly detailed AU build threads. He is a fountain of AU knowledge.
Originally Posted by OzriderXR8 View Post
Someone on another forum has tried this and it appears to work.
it seems if you "edit" the thread and then add "~original" to the end of the URL of the picture, the picture is visible again
But how do you edit? The edit function lapses after a few minutes.
PridenJoy is offline   Reply With Quote Multi-Quote with this Post
Old 26-07-2017, 11:23 AM   #184
Fed
You can upload straight to this forum and if you're doing it on other forums you should know how, it's easy enough.
Fed is offline   Reply With Quote Multi-Quote with this Post
Old 26-07-2017, 07:18 PM   #185
78xcgxl
78xcgxl's Avatar
All my old threads are buggered. Oh well, end of an era i guess.
78xcgxl is offline   Reply With Quote Multi-Quote with this Post
Old 26-07-2017, 08:34 PM   #186
XB GS 351 Coupe
This forum is completely different and does not give you the same options as others.
If I could upload photos straight from my computer I would not have wasted my time using photobucket.
Mike's Man Cave
Old 26-07-2017, 10:42 PM   #187
OzriderXR8
OzriderXR8's Avatar
Yep, other forums have allowed editing, I've been slowly replacing key photos on motorcycle and resto sites.
(by replacing stuff, not by the method mentioned....I deleted my Photobucket account)
Cheers Ozrider
AUII XR8 200KW
FG MK2 XR6
Mini 850
Rover P5 3 Litre Mk1
OzriderXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 26-07-2017, 11:49 PM   #188
BFIIGhiaZF6
George
BFIIGhiaZF6's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: The experience, information and willingness to help and share data in regards to the ZF cooling system options has probably cleared a lot of doubt about air/oil coolers and the ZF transmission.
Have been trying out the alternatives to PB and to date find PB and Imgur the easiest to use.
I have a paid PB account and find it very easy to use, also have free Flickr and Imgur accounts and some AFF gallery images.
Flickr is very difficult to navigate, not impressed at all.
AFF is greatly limited by file size, but otherwise easy to post pics to.
Here's a pic using Imgur, done in two clicks including change to file size, signed up and was using it within 2 minutes with ease, reckon its the best current alternative to PB.
BFWSMhttps://fordforums.com.au/vbportal/v...articleid=1708
ZF:http://fordforums.com.au/wsmpub/bf/307-01B.html
2007 BFII Fairmont Ghia I6 4L, ZF6 Auto, Ego Charcoal, Warm Charcoal.
R/Up 2019:Winner 2023:, Best BA-BF Geelong AFD.
PWR Air/Oil Cooler, K&N, Egas elbow, V8 upper F6 lower CAI.
1997 Fairmont EL Ghia Tickford 4L Auto
1985 Falcon XF GL 4.1L Auto.
1979 Fairmont XD Ghia 4.1L Auto.
1971 Cortina GL Estate 1200cc Manual.
BFIIGhiaZF6 is offline   Reply With Quote Multi-Quote with this Post
Old 26-07-2017, 11:51 PM   #189
I will keep my photobucket account so I can keep my photos, but transfer them one at a time as I need them.
Someone mentioned Flickr. I might look into that.
Thanks, will look at Imgur too.
Old 27-07-2017, 08:52 AM   #190
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
I'm using imgur now and its ok, less ads popping up. I have installed 2 ad blockers in Firefox to cope with the ads in Photobucket. I have tried the ~original and it works sometimes at the moment.
Uk
Old 27-07-2017, 10:42 AM   #191
Fed
The file limit here is 146.5 KB + 1600 x 1200 which is easy to achieve and plenty IMO.
Old 27-07-2017, 03:39 PM   #192
XB GS 351 Coupe
I nearly deleted mine the other day, but then decided to leave my Photobucket account alone just in case they wake up to themselves, not likely but you never know, I am not paying for an account, ever, they make enough money with advertising etc so no one should have to pay IMO.
If nothing changes soon, I will be deleting the account and that will be the end of it for me for a while, could not be stuffed starting again and all my build threads that have been going for years are useless now.
Mike's Man Cave
Old 27-07-2017, 03:49 PM   #193
Fed
Anyone with a 'build thread' could create a new post & upload all the pictures that are missing in one hit, better than nothing.
Old 27-07-2017, 07:26 PM   #194
jstanovic
Beware, the likes of Flicker/Imgur etc all don't let you host images there. It's in the terms and conditions, they just turn a blind eye to it at the moment. They will go the same way as Photobucket one day.....
jstanovic is offline   Reply With Quote Multi-Quote with this Post
Old 27-07-2017, 07:31 PM   #195
Grippy
Racing improves the breed
Grippy's Avatar
Are photobucket phasing out free hosting gradually? All pictures in my build thread are still working.
1970 Mini Cooper S Historic Group Nc Touring car
1964 Mini Cooper S Historic Group Nb Touring car
Victorian Hill Climb Championship
Grippy is offline   Reply With Quote Multi-Quote with this Post
Old 27-07-2017, 08:31 PM   #196
Paul302351
Paul302351's Avatar
facebook is the real winner out of all of this..
Paul302351 is offline   Reply With Quote Multi-Quote with this Post
Old 28-07-2017, 06:03 AM   #197
jpblue1000
jpblue1000's Avatar
I Think the more bandwidth your images attracted the quicker you got turned off. Low volumes of traffic to your hosted photos mean they haven't found you yet is my guess.
~original is working for now.
JP
jpblue1000 is offline   Reply With Quote Multi-Quote with this Post
Old 28-07-2017, 09:08 AM   #198
Photobucket members using 3rd party hosting who were using over 10Gb of bandwidth were the first to be targetted (including me). They are slowly working through and turning off users over time.
With millions of users it takes awhile to get to everyone it seems.
Old 30-07-2017, 10:42 AM   #199
Maka
Au Falcon = Mr Reliable
Maka's Avatar
My photos are gone too now, thanks for the headache photobucket lol, now to try & fix, dohh. :(
cheers, Maka
Old 31-07-2017, 11:21 PM   #200
Pepscobra
Call me dirt... Joe Dirt
Pepscobra's Avatar
So has anyone else discovered Postimage? https://postimages.org/
Its free and so easy to use for just posting photos on forums.
Is it too good to be true? Is there a catch I need to be aware of?
Have tried flickr and imgur, but they are too messy for what I need them for.
2007 BFII FPV Cobra Ute|Boss 302|6M|#23/100
Mods so far:
Billet Products Shifter|X-Force Exhaust|Herrod Oil Breathers|Whiteline Sway Bar|Tein SuperStreets|Kings FOR-303SL Rear Springs|Melling Oil Pump|Mace Manifold Spacers|Powerbond Underdrives|Pacemaker Headers|Ballistic Cats|XFT Custom Tune @ 308.3rwkw|DBA T3 Rotors|Ferodo Pads|Goodridge Braided Lines
Mods to come:
4.11 Diff Gears|Chromoly Tailshaft
I use & recommend:
Castrol|Motorcraft|Mainlube|Penrite
Check Out My Build Thread
Pepscobra is offline   Reply With Quote Multi-Quote with this Post
Old 01-08-2017, 12:10 AM   #201
jstanovic
From their website:
"Please keep the images embedded into third-party websites wrapped in links back to the corresponding HTML pages at our site when possible. The outgoing link should lead the user directly to our web page without any interstitial pages or interruptions. This allows your users to get access to the full-resolution images, and also helps us pay our bills."
Does this mean that you can only put up the link address, not the [img] link so the pics are automatically shown in a post?
Old 01-08-2017, 01:16 AM   #202
Dezza
Parts bin special
Dezza's Avatar
I've started using postimage and seems to work well for me. No complaints at all.
Weekender 1964 US Falcon Futura convertible - Rangoon Red
260 Windsor V8, 4 speed manual, LHD, Electronic ignition, Mustang wheels
https://fordforums.com.au/showthread.php?t=11470868
Daily 2010 FG XR50T ute - Lightning Strike
6 speed manual, XR8 bonnet, hardlid, Streetfighter airbox
Previous Cars 1990 EAII Fairmont Ghia - Tickford engine, 5 speed, SVO wheels, bodykit, much more
2000 AUII Fairmont - XR wheels, Ghia interior
Dezza is offline   Reply With Quote Multi-Quote with this Post
Old 01-08-2017, 11:44 AM   #203
BFIIGhiaZF6
George
Just signed up on postimages, all good so far
As simple to use as Imgur is.
As long as you mention them when posting they seem to be happy with 3rd party posting.
Courtesy of PostImage
Old 01-08-2017, 12:25 PM   #204
BFIIGhiaZF6
George
Works well, very easy on PC
Courtesy of PostImage,
Now how do we update all our posts in AFF?
Old 01-08-2017, 04:33 PM   #205
Pepscobra
Pepscobra's Avatar
Seems fair enough, why not give them a plug when posting photos.
I'm happy with it too so far, basic and straightforward.
I might change my signature to include a reference to PostImage.
Mods so far:
Mods to come:
I use & recommend:
Old 01-08-2017, 04:51 PM   #206
GasoLane
Former BTIKD
GasoLane's Avatar
The way I read their Terms of Use is that they just want a direct link back to their site. As in if you click in the pic it goes to the Postimage site directly.
I didn't see any mention of them wanting recognition.
Or am I reading this wrong?
Old 01-08-2017, 05:10 PM   #207
BFIIGhiaZF6
George
That's right, but also says this,
"By downloading an image or copying other user-generated content (UGC) from PostImage, you agree that you do not claim any rights to it. The following conditions apply:
You may use UGC for personal, non-commercial purposes
You may use UGC for anything that qualifies as fair use under copyright law, for example journalism (news, comment, criticism, etc.), but please include an attribute ("PostImage" or "courtesy of PostImage") next to where it is displayed."
Just want to make sure they are happy
Have only downloaded about 50 of about 1500 images to them so far, all resized to 320x240, don't know what the limit is?
Old 01-08-2017, 05:46 PM   #208
BFIIGhiaZF6
George
Just downloaded another 50 full size to them, here's one,
Thanks for the tip Pepscobra
Old 01-08-2017, 07:07 PM   #209
Pepscobra
Pepscobra's Avatar
What size are you uploading them as mate?
I'm doing mine mostly as 800x600
Mods so far:
Mods to come:
I use & recommend:
Old 01-08-2017, 07:41 PM   #210
BFIIGhiaZF6
George
Not sure about that last one, still getting the hang of it, but love it, using iPad too sometimes, though not as easy as PC, like this one, thumbnail for forum,
[url=https://postimg.cc/image/e22lcp16d/][img]https://s26.postimg.cc/e22lcp16d
