Old 23-03-2023, 10:58 AM   #1
Aus911
Question Cortina Mk2 Column Shift Bushes
Hi All,
Im in the process of getting my Cortina Mk2 back on the road. It has the 4 speed column shift which is not shifting well.
I inspected the linkages and found 2 bushes completly missing and others that need replacing. I think I have identified the missing ones see attached pic
#1 is missing and seems to be 12.7mm 1/2inch Inside Diameter, 19.05mm 3/4 Outside Diameter but I'm not sure how long and I guess it is flanged. I am considering BF0127-0191-0381-BS2432TH
#2 and #4 seem to be the same, they are still in place but it would be nice to replace them anyway they seem to be 6.35mm 1/4 in ID, 14.287mm 9/16 OD and 8mm long with a flange but I cant find a suitable replacement.
#3 is missing and seems to be 9.525mm 3/8 in ID, 15.87mm 5/8 OD and 8mm long?? I am considering BF0095-0159-0095-BS1932TT and making it fit.
Does anyone know the recommended bush sizes?
Does anyone know where these bushes can be sourced?
And your thoughts on my plan?
Any other recomendations to get the column shift operating well?
Thanks in advance
Ray
Aus911 is offline   Reply With Quote Multi-Quote with this Post
Old 23-03-2023, 09:59 PM   #2
foxtrot3
foxtrot3's Avatar
Default Re: Cortina Mk2 Column Shift Bushes
Hi. Try Yesterford in bayswater. 03 9761 4714. Cheers MD
HI
I'M MICHAEL
foxtrot3 is online now   Reply With Quote Multi-Quote with this Post
Old 23-03-2023, 11:47 PM   #3
GTLEGEND
Contact this seller..
https://www.ebay.com.au/itm/19492623...3ABFBM0NKL5OFh
Old 24-03-2023, 01:57 PM   #4
Aus911
Hi Foxtrot3 and GTLEGEND,
Yes I spoke with Yesterford but they can't help.
The EBay listing looks interesting, great info there, but I think I will see how I go getting bronze bushes to suite, they look like plastic? I may contact him and see if he has anything else.
Thanks again!
Ray
Old 24-03-2023, 03:15 PM   #5
39ClevoUte
39ClevoUte's Avatar
Do know anyone with a lathe? Probably about $20 or free if you ask around of polyurathe rod and your done.
39ClevoUte is offline   Reply With Quote Multi-Quote with this Post
Old 24-03-2023, 04:20 PM   #6
Aus911
Hi 39ClevoUte,
Yep, if I had access to a lathe that is what I would do.
I thought about 3d printing but I think they may not last long. Hopefully I can find a supplier of bronze bushes in the required size even if I have to fine tune them...
Thanks for your thoughts!
Ray
Old 24-03-2023, 04:24 PM   #7
GTLEGEND
Try someone like the below:
https://www.ebay.com.au/itm/28339782...Bk9SR7rkz53iYQ
or
https://www.ebay.com.au/itm/22142386...3ABFBMuOTPneJh
Old 24-03-2023, 07:24 PM   #8
39ClevoUte
39ClevoUte's Avatar
I'd troll a few industrial estates and I reckon you would find someone willing to do it.
