Old 05-01-2007, 02:42 PM   #1
willygrice
Default What 5 speeds can go in an Escort?
What 5 speed manual gearboxes can go in an Escort, and what Engines go with them?
willygrice is offline   Reply With Quote Multi-Quote with this Post
Old 05-01-2007, 04:41 PM   #2
cortina-mk1
Heavy right foot
cortina-mk1's Avatar
toyota 5 speeds with a conversion kit
nissan 5 speeds with a nissan engine
or even later ford 5 speeds but all will require modifications etc to fit
cortina-mk1 is offline   Reply With Quote Multi-Quote with this Post
Old 06-01-2007, 01:55 AM   #3
willygrice
what Nissan engine and gearbox's are you referring to?
Old 06-01-2007, 03:04 AM   #4
fmc351
let it burn
If it was an auto, the gearbox turret is larger and a Sierra 5 speed will fit, so I've read. Was looking at doing a panel van.
Old 06-01-2007, 04:00 AM   #5
willygrice
What 5 speed would go with a Mazda 13B Rotary? How hard would it be to fit?
Old 06-01-2007, 09:06 AM   #6
cortina-mk1
Heavy right foot
a 5 speed mazda rotary gearbox
nissan sr20 or ca18
you can look here for pics on how these fit
www.cortina-mk1.com/sr20.php
Old 07-01-2007, 01:00 AM   #7
willygrice
sierra? what engine would go with that?
Old 07-01-2007, 03:42 AM   #8
fmc351
let it burn
Sierra as in Ford Sierra (little pocket rocket from the UK, they ran Cosworth 600hp versions at Bathurst, made V8 Commodore fans cry, there are standard versions too though), not the Suzuki 4wd thing. From what i read, they use adaptors, or modified bell housing to bolt to the Escort motor. If youve got one available, I dont see why you couldnt get a Sierra motor in though.
i never actually did it, so youll need to check facts, its just what I read when I entertained the idea of doing an Escort panel van.
Out of all the conversions, the rotary is probably the easiest, they are tiny to look at, and carb fed. It would just be getting it done.
Old 07-01-2007, 11:51 AM   #9
mk2maniac
I would suggest a celica gearbox, with conversion kit. That'd be the way I'd go. Im pretty sure Castlemaine does a conversion kit.
mk2maniac is offline   Reply With Quote Multi-Quote with this Post
Old 08-01-2007, 07:47 PM   #10
cortina-mk1
Heavy right foot
but depending upon what engine you choose its best probly to use a 5 speed that came with it
Old 09-01-2007, 11:17 AM   #11
mtbme
where can you get a sierra gbox in sydney?
mtbme is offline   Reply With Quote Multi-Quote with this Post
Old 09-01-2007, 06:49 PM   #12
mk2maniac
Yes, you are correct, that'd be the most hassle free way. But if you were using a 2 litre Pinto or something, I think a Celica gearbox would be a very good choice. I have a contact who specialises in making custom conversion kits to fit a celica or supra gearbox to virtually any engine.
Old 10-01-2007, 06:35 AM   #13
cortina-mk1
Heavy right foot
my first suggestion was just that
toyota 5 speed
Old 11-01-2007, 10:00 PM   #14
fordy19
Renee
A sierra 5 speed (out of standard 2 ltr - not twin cam) will pretty much bolt straight up to any mk3 - mk5 cortina engine, hope this helps
fordy19 is offline   Reply With Quote Multi-Quote with this Post
Old 11-01-2007, 11:59 PM   #15
Aussie_Escort
Aussie_Escort's Avatar
This is just my opinion but I think the celica gearbox has the worst ratios!!! I would go the sierra 5 speed. A lot cheaper and easier to do and i think has much better ratio's.
Just my thoughts.
Cheers,
Aussie_Escort
Aussie_Escort is offline   Reply With Quote Multi-Quote with this Post
Old 12-01-2007, 02:34 AM   #16
mickas
Sierra's have worse ratios
go a supra 5 speed w58
mickas is offline   Reply With Quote Multi-Quote with this Post
Old 12-01-2007, 04:59 PM   #17
RS027
Perth XR5'er
RS027's Avatar
Sierra Type 9 Box. Same ratio's as a Escort 2L box, but with an over driven 5th. 100kph is aroung 2900 revs. Will bolt staight up to a 2Lt Pinto, however an Auto tunnel needs to be put in or just do what I did. A few well places hits with a mallet. $500 2ndhand or about $1000 reco.
Ford Rallye Sport Club of WA; Member#64:
Barbagallo Short: 1:01.1779
Barbagallo Long: 1:12.4649
Collie: 55.90
K&N Gen2 57i CAI / 2XS RIP / Airtec Gen3 IC / Mongoose Dump Pipe / Outlaw 200cpsi Cat / Milltek Ultimate Race Catback / Whiteline 24mm RARB / Whiteline FALK / BC Racing BR-Spec Coilovers / RSR Rear Camber Arms / Ferodo DS2500 Pads F&R / Goodridge Braided Brake Lines / Elevate Torque Mount / DS MOD C / MkII RS Clutch & DMF / Quaife LSD
RS027 is offline   Reply With Quote Multi-Quote with this Post
Old 12-01-2007, 09:07 PM   #18
Aussie_Escort
Originally Posted by RS027
Sierra Type 9 Box. Same ratio's as a Escort 2L box, but with an over driven 5th. 100kph is aroung 2900 revs. Will bolt straight up to a 2Lt Pinto, however an Auto tunnel needs to be put in or just do what I did. A few well places hits with a mallet. $500 2ndhand or about $1000 reco.
Couldn't agree more. It's the way to go. A lot easier & cheaper than a supra box, assuming your bolting it to a pinto.
Good luck finding a w58 box then good luck with the price.
Old 13-01-2007, 06:38 PM   #19
T_Mark
Esky Driver
T_Mark's Avatar
Yep definately the sierra type 9, 5 speed
T_Mark is offline   Reply With Quote Multi-Quote with this Post
Old 04-02-2007, 04:36 PM   #20
delboy
Default celtic
i have a few sierra boxes for sale in sydney, if anyones interested.$500 each including shifter,fork,release bearing and mount.0412218885.
delboy is offline   Reply With Quote Multi-Quote with this Post
Old 05-02-2007, 04:50 PM   #21
Juiceman
35KIE
Juiceman's Avatar
Also with the Sierra 5spd you need to fabricate new mounts for the g/box crossmember and make a new hole for the shifter a little further back.
Track Red Mk2 Escort RS2000 Replica
Juiceman is offline   Reply With Quote Multi-Quote with this Post
Old 15-02-2007, 09:10 PM   #22
greenmk2
75 MK2 2 Door
greenmk2's Avatar
I have celica 5 spd. I had to put a auto tunnel in it. with a falcon 389/1 diff rev's at 3400rpm doing a 100kph.The dellow bellhousing is pretty poor. Starter motor thread's strip easy. Had problem's finding spiget bearinjg to suit..
greenmk2 is offline   Reply With Quote Multi-Quote with this Post
Old 15-02-2007, 11:00 PM   #23
monkeydog
Shift for brains
When I took my car (2ltr 4spd manual) for it's first 100km/hr run I thought I might need to look at a 5 speed when the rpms sat around 4100. After new spark plugs and timing it now sits about 3000rpm, pretty impressed.
A 5 speed would have to cut that down a fair bit in fifth now for me to be interested again I think.
monkeydog is offline   Reply With Quote Multi-Quote with this Post
Old 17-02-2007, 10:46 AM   #24
outback_ute
Ute Forum Moderator
Contributing Member
outback_ute's Avatar
Huh? New plugs etc shouldn't change the cars gearing. Maybe the tacho is working properly.
Old 17-02-2007, 03:38 PM   #25
monkeydog
Shift for brains
Probably, doesn't sound like it's running as fast/loud/(working as hard to get) on 100km/hr though
Old 24-02-2007, 10:36 PM   #26
monkeydog
Shift for brains
Probably should ignore my post above, I had a think about things logically. Oops.
Old 17-03-2007, 07:33 PM   #27
escortzetec
escortzetec
go the ford sierra 5spd its cheap it'll bolt up to any ford engine with its standard bell housing from anglia engine, escort engines, cortina engines and even a 97 ford mondeo zetec twin cam, and you dont have to cut up the body apart from the gear lever hole and drill some mounting hole in the floor use a hillman hunter drive shaft and the sierra speedo cable, and you can buy a standard clutch to fit in its all really easy
escortzetec is offline   Reply With Quote Multi-Quote with this Post
Old 18-03-2007, 06:52 PM   #28
blueline
ambitious but rubbish
blueline's Avatar
escortzetec, did you fit your sierra 5 speed to a coupe or a sedan? the hillman hunter driveshaft fitting sounds good, but i dont wanna go chasing down a driveshaft then finding out it is too short. is the hillman hunter the one with the 1725cc engine?
Come check out my automotive blog, you might just find something you like...
www.themanifold.me
blueline is offline   Reply With Quote Multi-Quote with this Post
Old 18-03-2007, 10:06 PM   #29
outback_ute
Ute Forum Moderator
Contributing Member
Most Hillman Hunters have the 1725 engine, but the 1600 version shares the same block. They look a bit like Mk2 Cortinas. If you look in the right place you can probably get a driveshaft (if not a whole car) for free - get in touch with the Hillman Owners Club if you decide to go down that route
Old 20-03-2007, 12:16 AM   #30
blueline
blueline's Avatar
will do, thanks outback_ute
www.themanifold.me
