Old 20-09-2017, 06:01 PM   #1
tashmac
Default Capri MK1 Wheel
Hi All
Hoping someone may be able to tell what rims would fit a 71 Capri, or where i could get one in Sydney, just need it for the spare wheel ?
Thanks
Mark
tashmac is offline   Reply With Quote Multi-Quote with this Post
Old 21-09-2017, 07:04 AM   #2
russellw
russellw's Avatar
Default Re: Capri MK1 Wheel
So, the standard was a 13x5". Stud pattern is 4 x 4.25" (4 x 108 for metric) and the offset is 19mm (20mm in some markets).
Some markets had a 14x6" option with the same PCD but an offset of 10mm.
In terms of wheels that will fit, you've got a fairly large choice but for things that are fairly common in Australia:
Cortina TC/TD/TE/TF
Escort MkII
(early) Ford Ka
(early) Mondeo
Leyland Marina
Russ
Old 31-10-2017, 09:06 AM   #3
chefo
Is this offset + or - 20mm? I’m looking at moving from 13” to 15” to house a large disk brake setup on front (mk1 Capri). Thank you!
chefo is offline   Reply With Quote Multi-Quote with this Post
