Old 25-07-2015, 06:44 PM   #1
stehowardtlr
Default Laser kn miss firing
Hi all, I have a 2000 model kn laser. It started chugging and miss firing today. Only when at low revs, on the freeway it's fine. Its a manual so I can drop the clutch and give it some big revs when setting off. If I don't it feels like it's running on 2or 3 cylinders.
Any ideas? I'm thinking ignition coil and/or leads
stehowardtlr is offline   Reply With Quote Multi-Quote with this Post
Old 27-07-2015, 01:59 AM   #2
FERG_51
Default Re: Laser kn miss firing
Common fault is coils on those cars. Id also do plugs and leads.
FERG_51 is offline   Reply With Quote Multi-Quote with this Post
Old 27-07-2015, 09:12 PM   #3
dirty hands
Over Thinker
dirty hands's Avatar
time for a good service
My car goes Brumm Brumm
dirty hands is offline   Reply With Quote Multi-Quote with this Post
Old 17-07-2019, 11:30 AM   #4
Rollers123
Did changing coils fix it? if so, which brand of coil? I've the same issue withmy KN , changed plugs which sorted some of the problem...i have fuelmiser coils in it but this brand is not favoured...
Rollers123 is offline   Reply With Quote Multi-Quote with this Post
Old 17-07-2019, 12:28 PM   #5
PG2
#neuteredlyfe
PG2's Avatar
Coils will more than likely fix it. Had the same problem with my the daughter's Laser. Park it somewhere dark, pop the bonnet and start it up then watch the light show.
I replaced the coils about 12 months ago with fuelmiser and have had no issues.
Old 17-07-2019, 09:47 PM   #6
GTLEGEND
1.6 or 1.8?
