Old 11-05-2009, 09:42 PM   #1
russellw
russellw's Avatar
Default Searchable DTC Database **UPDATED**
Good evening
It's not yet complete but we have put together a Diagnostic Trouble Code lookup database where you can search for them.
You'll need to select a model from the drop down list and know the DTC code as the search will only return a maximum of three results.
Codes for models from AU onward will start with B (Body related), P (Power train related) or U (CAN related) and we will keep adding to the data over the next few days.
Models prior to AU have numeric codes without a prefix.
Note: if you find insufficient data on a code under one model, try using the REF code explained below.
At present we have EF, EL, AU, BA, BF and FG uploaded.
There is also a reference database (REF) included that gives considerably more detail for each "P" type DTC up to P1900. The column headings for REF based searches (Mechanical / Sensor / Electrical) are not ALWAYS applicable and these should be read as Explanation / Possible Causes and Diagnostic Aids.
**The REF database has been updated to include Ranger DTC's**
Search Form is HERE
Russ
Old 06-09-2010, 03:34 PM   #2
vevapower
vevapower's Avatar
Great thanks! Now that the XCAL 3 can log DTC codes and then clear them this data base for yours will save people heaps of coin taking their cars to a workshop!
vevapower is offline   Reply With Quote Multi-Quote with this Post
Old 25-04-2012, 11:44 AM   #3
raalwa
Default Re: Searchable DTC Database
Hi I have 2 codes P0500 and U1039 I think these may be related.Your thead mensions tyre size change.I ghanged from 215/65/16 to 215/60/16 6 months ago and this code has appeared now.Could this be the problem.Thanks Alan
raalwa is offline   Reply With Quote Multi-Quote with this Post
Old 25-04-2012, 12:54 PM   #4
russellw
russellw's Avatar
While it's possible I'd be rather nmore suspicious of a faulty wheel speed sensor or similar. If you can get to someone with a WDS or other programmer then you could try resetting the tyre size in the VID block and see if the errors go away.
Russ
Old 01-06-2012, 01:27 PM   #5
cruze
FG XR6T
This is fantastic ! thanks....
I am recieving a code that does not appear: P2154 ......?
cruze is offline   Reply With Quote Multi-Quote with this Post
Old 02-06-2012, 01:35 AM   #6
russellw
russellw's Avatar
There is a B2154 - Front Echo Sensor Circuit Failure which is generated by the CSM (Central Security Module)
Russ
Old 23-10-2012, 10:01 PM   #7
Luke Plaizier
Lukeyson
Luke Plaizier's Avatar
Is it time to consider a PID database.....?
Lukeyson
If the human brain was simple enough to understand, we'd be too simple to understand it.
Luke Plaizier is offline   Reply With Quote Multi-Quote with this Post
Old 23-10-2012, 10:13 PM   #8
russellw
russellw's Avatar
The PID's for most late models are in the tech portal currently. It's not much of an effort to make that into a database table and the create the search form but it depends if there is enough demand.
Russ
Old 31-05-2013, 08:34 PM   #9
in shock
This is the best web site ever, as a retired Auto Enginneer this is an absolute gift for valuable reliable info.greaaaaat stuff !!!!! With Ford on the way out (and I have bought many new Fords) and currently own the last of the BF Wagons and sad to say a troublesome brand new SZ Territory with 17 faults as a free gift, this web site will be an owners salvation. Getting any info from Ford is harder than winning LOTTO, so go for it bring it on and RUSSELL W for P.M
in shock is offline   Reply With Quote Multi-Quote with this Post
Old 31-05-2013, 11:42 PM   #10
russellw
russellw's Avatar
Thanks for the kind words. I think I'm probably more use here than running the country
Russ
Old 26-11-2013, 12:58 AM   #11
mccoy54wru
I'd rather be cycling
My BA is reporting through FORscan the code PCM P1213-63. Are the suffixes in the database somewhere, or is there a recommended way to find their meaning?
I see that the P1213 error in the forum DTC database is "Gas start injector circuit failure", and there is some detail in the BA Workshop Manual with Description and Possible causes.
Ta.
===DTC P1213-63===
Code: P1213 - Cold Start Injector #1
Additional Fault Symptom:
- Signal is Above Maximum Threshold
Status:
- DTC Present at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
Module: Powertrain Control Module
Diagnostic Trouble Code details
===END DTC P1213-63===
mccoy54wru is offline   Reply With Quote Multi-Quote with this Post
Old 15-08-2014, 06:37 PM   #12
nstg8a
3..2..1..
nstg8a's Avatar
Default Re: Searchable DTC Database **UPDATED**
This may not be the right place, but my lane is throwing up two fault codes
po340 which from using the database is camshaft position sensor
And
po443. In the database the search found nothing? Anyone know what it is?
Originally Posted by pottery beige View Post
Happy mcgadget meal orphan mcboofhead
nstg8a is offline   Reply With Quote Multi-Quote with this Post
Old 15-08-2014, 06:45 PM   #13
russellw
russellw's Avatar
It's there under the REF section.
DTC # P0443
Description: EVAP solenoid / circuit failure (EVAP).
Mechanical:
Sensor: Solenoid failed.
Electrical: Damaged or defective wiring or connections.
Other: Defective PCM.
Russ
Old 15-08-2014, 07:35 PM   #14
nstg8a
3..2..1..
nstg8a's Avatar
DTC # P0443
Mechanical:
Russ
Awesome, thanks russell
Old 23-10-2014, 12:15 PM   #15
lowlanda
lowlanda's Avatar
Amazing stuff, thank you so much!
Complexity is Multitude of Simplicity
lowlanda is offline   Reply With Quote Multi-Quote with this Post
Old 18-03-2019, 06:31 PM   #16
mhyne
Out of interest, can someone tell me what the best tool is for reading these codes.
I did try using one of those bluetooth ODB-II readers but it did not seem to read fault codes.
The Ford dealers told me that an ODB reader wont be able to read most of the fault codes and you need a proprietary tool that only dealers can get hold of.
Is this correct ?
(I have a BA Falcon and a SZ Territory with a combination of faults I am debugging the old way).
mhyne is offline   Reply With Quote Multi-Quote with this Post
Old 19-03-2019, 08:57 AM   #17
russellw
russellw's Avatar
No it's not correct. Start with a read of THIS article but there are several non IDS readers than have no problem reading the major codes.
Russ
Old 19-03-2019, 11:42 AM   #18
mhyne
thanks Russell. I will have a play with that tool and my OBDII reader and see if I can get some codes out of the unit.
