Old 14-04-2017, 11:27 PM   #1
Pazuzu
Default 07 LT TDCI rear indicator problem
Hi all,
Rear left indicator's on the fritz. Change of bulb has done nothing. Suspect bulb holder is stuffed, but last time this happened on LHS the mechanic replaced the entire assembly.
Has anyone else encountered this? Are the bulb holders worth trying to fix DIY, or is a new assembly cheap enough?
Pazuzu is offline   Reply With Quote Multi-Quote with this Post
Old 15-04-2017, 09:08 AM   #2
DZFord
DZFord's Avatar
Default Re: 07 LT TDCI rear indicator problem
Yeah my rear indicator was also intermittently playing up. Globe was always ok. Changed the globe holder and it fixed the issue. I assumed it was an issue with the contacts. Relatively cheap fix from memory.
Old 03-07-2017, 10:46 PM   #3
disco stu III
what?
Same, two or three years ago. Electrical cleaners were a very temporary fix. About ten minutes it lasted. New bulb carrier= success. A lot of leaves in the same area. Maybe it's not real good at sealing there. Water leaves residue, no current path?
disco stu III is offline   Reply With Quote Multi-Quote with this Post
