Old 06-04-2007, 05:24 PM   #1
toyotaxr8
toyotaxr8's Avatar
Default How to remove the abs fuse
can someone help me i cant get the abs fuse out is there any trick to get it out
MR INCH
toyotaxr8 is offline   Reply With Quote Multi-Quote with this Post
Old 06-04-2007, 05:26 PM   #2
AUIII XR8 MAN
DJR TM#54
AUIII XR8 MAN's Avatar
Long nose plier might help.
When traveling to V8 Supercar rounds, i book through KYLEE MOLE Travel agents, She Goes, She Goes, She Goes & I just went.
Now Zetec Powered. 1.6lt of madness. But the XR8 still remains
AUIII XR8 MAN is offline   Reply With Quote Multi-Quote with this Post
Old 06-04-2007, 05:38 PM   #3
toyotaxr8
toyotaxr8's Avatar
tried it still tight even with two pairs of long nose
MR INCH
Old 06-04-2007, 06:04 PM   #4
AUIII XR8 MAN
DJR TM#54
Try spraying some thing like WD40 on it?
That must be one stubborn fuse.
Old 06-04-2007, 06:28 PM   #5
GK
Walking with God
GK's Avatar
I've never known a fuse to be that stubborn. I wonder what's up here?
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 06-04-2007, 06:45 PM   #6
ratter
ratter's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Shares his in-depth tuning knowledge with the forum, very helpful. Contributor: For members who make a contribution worthy of recognition. - Issue reason: For his indepth tutorial on adding borders to photographs
Not sure which type of fuse you have, but some slow blow fuses are actually bolted in
Pit Lane Performance
20 Rosella St Frankston 03 9783 8122
Authorised Streetfighter, Pcmtec , SCT & HP Tuners Tuning Agent,
ratter is offline   Reply With Quote Multi-Quote with this Post
Old 06-04-2007, 08:04 PM   #7
Jastel
Technical Contributor: For members who share their technical expertise. - Issue reason: Has much experience with taxis and always jumps on here to explain things simply and help out the new guys in B-series and Contemporary...
The ones under the dash should just pull out with the little plier tool provided
Some of the hi ampage ones in the fuse box under the engine are bolted in, a short 10mm bolt goes through the prongs of the fuse from memory
You have to lever fuse panel out of the box part and you can then access the bolts, there are 3 or 4 points you must click out so you can lift the fuses up out of the box
Jastel is offline   Reply With Quote Multi-Quote with this Post
Old 30-07-2018, 04:43 PM   #8
Evan R
Default Re: How to remove the abs fuse
They are bolted in and as mentioned before you have to remove 4 tabs and lever plate up it is a tricky job but with patience it can be done
Evan R is offline   Reply With Quote Multi-Quote with this Post
Old 14-12-2021, 04:11 PM   #9
scrubber
KICK START
scrubber's Avatar
very helpful thank you guys, thought they may have been secured from below, can anyone tell me if they are a fuseable link type fuse or the same as the ignition fuse so i can have the right one when i pull the box out. thanks
scrubber is offline   Reply With Quote Multi-Quote with this Post
