Old 10-07-2010, 08:53 PM   #1
BigCav
OzFalcon.com.au
BigCav's Avatar
Default kh laser 1.8 sohc idle surge
Hi guys
I'v just bought a first car for my brother, a 1991 ford laser s 1.8 sohc
now i absolutely love the car, almost dont want to give it too him haha
but i do have a single issue, the engine will randomly hunt/surge from idle
makes 1/10th of ****** difference when driving but when your at the lights or puttering around its really annoying and embarrasing
will idle fine at around 1000 rpm or so, and will jump up to 1800-2000rpm for no reason
is this common? easy fix?
previous owner said it was the airflow meter but i fail to see how this would affect it enough at idle, im more inclined to think coolant sensor or something?
does the ecu have a self diagnosis function? if so how do i read the codes etc?
BigCav is offline   Reply With Quote Multi-Quote with this Post
Old 10-07-2010, 09:30 PM   #2
Auturbo6
The only thing u'll see!!
Auturbo6's Avatar
Make sure the TPS is set correctly and the throttle butterfly hasn't been played with, as second rate mechanics will use this to compensate for idle motor issues (Coolant operated devise bolted to the front of the plenum chamber). Later.
My car has launch control, simply BAM-BAM-BAM-BAM-BAM-BAM-BAM then select D for maximum respect, it bushfires the s**t house everytime!!!
Auturbo6 is offline   Reply With Quote Multi-Quote with this Post
Thread Tools
Display Modes
