Old 08-03-2007, 09:18 AM   #1
linchpin
Default el transmission fluid
May seem a silly question but how can I check my tranny fluid level on el ghia?
1997 EL Ghia dual fuel - stock as can be
linchpin is offline   Reply With Quote Multi-Quote with this Post
Old 08-03-2007, 01:23 PM   #2
BRADMAN
BA Mk2 XR6 Turbo
BRADMAN's Avatar
put the rear of the car on jacks so its slightly down hill.
slide under the car on drivers side
just beside cat towards the rear of the box half way up is a 12mm (i think) bolt.
undo the bolt. and trans oil should just start coming out, so if it does quickly do up bolt n ur all good.
if not add more fluid.
hope it helps
brad
2005 - BA mk 2 - XR6T - 4.0ltr Turbo - 6 Speed Manual
Blue Power Airbox, Sunroof, Typhoon Wheels, Brembos, Prem Sound, Momo Chunky Wheel, Genuine FPV Gauge Holder, Whiteline Swaybars, Lowered, Tinted Windows, 60lb Injectors, Plazmaman Cooler, Hot Side & Under Battery Pipes, 4" Dump & Cat, Process West Surge Tank & Bosch 044, Turbo Inline Oil Filter
BRADMAN is offline   Reply With Quote Multi-Quote with this Post
Old 08-03-2007, 07:47 PM   #3
webby_191189
low wagooon
hope it helps
brad
Autos dont have check plugs on the box if it even is an auto. Only manuals have check plugs. Autos have dipsticks
Webby
S2 AU XR6 UTE
webby_191189 is offline   Reply With Quote Multi-Quote with this Post
Old 08-03-2007, 07:54 PM   #4
accurate1
I can't believe the last two replies, firstly the car has to be jacked up level and secondly some transmissions do have plugs.
accurate1 is offline   Reply With Quote Multi-Quote with this Post
Old 08-03-2007, 07:54 PM   #5
frd_crzer
:D:D
frd_crzer's Avatar
not all autos have dip stick so that is a way to do it but the el auto trans should only have 1.9ltre in it
Cheers Grant
frd_crzer is offline   Reply With Quote Multi-Quote with this Post
Old 08-03-2007, 08:01 PM   #6
accurate1
1.9 lt. might be the refill quantity when removing the pan but the total capacity is something like 8 or 9 lt.
Old 08-03-2007, 08:53 PM   #7
BLSTIC
1.9L?
I have been putting 3-4L in mine whenever I drop the pan... 1.9L is the T5 dry fill.
BLSTIC is offline   Reply With Quote Multi-Quote with this Post
Old 08-03-2007, 08:53 PM   #8
BLSTIC
Then again, lately I have been taking the valve body out and apart on mine too...
Old 08-03-2007, 09:59 PM   #9
frd_crzer
:D:D
frd_crzer's Avatar
but ur doing a pan drop of course ur going to need 4 l but i read the el w/shop manual it said aithout pan empty it is 1.9l
Cheers Grant
Old 22-03-2007, 08:03 PM   #10
mike1959
Hi Guys
I am a girl so go easy on me okay..
I purchased a bright yellow
ex taxi ford falcon sedan.
I think it is 1998 or 1996 model
It is AUTOMATIC TRANSMISSION
Anyway in the last week or two
when I accelerate the transmission
does not change gears correctly
and kind of revs...
and when I turn the car off
it most times corrects itself
albeit temporaraily
ANYWAY since I have had the car 18 months,
I have never been able to find
the place to check the transmission fluid
so could you help me out firstly
and perhaps indicate what the problem may be
Please be nice guys
mike1959 is offline   Reply With Quote Multi-Quote with this Post
Old 22-03-2007, 09:02 PM   #11
BRADMAN
BA Mk2 XR6 Turbo
BRADMAN's Avatar
accurate1,
just to answer your post.
when a ford is lowered it tends to be *** heavy.
the jacking the rear slightly means that the car then becomes level.
mike1959,
you prob dont have a dip stick if its an EL.
if you read my post number 2 it should give u an idea on whats involved to check the fluid. otherwise a trans joint could check it for you
brad
Old 22-03-2007, 10:06 PM   #12
accurate1
[QUOTE=BJSPENCER85]accurate1,
Whether the car has been lowered or not has nothing to do with it, the body must be level to accurately check any fluid levels.
Old 22-03-2007, 10:29 PM   #13
Kenaz
Kenaz's Avatar
From EFII Falcons didn't get transmission dipsticks.
02 BA XR6 T U R B O
Venom Red, Auto 13.97 @ 101mph
Originally Posted by Wheels Nov 02
It's suave, more subtle, and yet no less stirring. In fact, the boosted Ford is more polished than any big sedan Australia has ever produced. It's just so damn good, it makes the SS feel crude... Ignore the WRX. Forget the E49. Falcon XR6 Turbo is king.
Kenaz is offline   Reply With Quote Multi-Quote with this Post
Old 22-03-2007, 10:36 PM   #14
Tiga_EL
Tiga_EL's Avatar
I know it sux.. those dipsticks are mad.. From now on i just servce my trans when it starts slippin.. Just got one yesterday and it *** hammers now
Tiga_EL is offline   Reply With Quote Multi-Quote with this Post
Old 22-03-2007, 11:00 PM   #15
frd_crzer
:D:D
frd_crzer's Avatar
the first thing im going to do to my ef when i get it is convert it to manual stuff auto. manual atw
Cheers Grant
Old 23-03-2007, 12:16 AM   #16
bigev
Bloke
More specifically, I'm pretty sure the EL was the *only* model not to have an auto dipstick, I'm pretty sure the AU's went back to having them.
bigev is offline   Reply With Quote Multi-Quote with this Post
Old 23-03-2007, 09:10 AM   #17
naughtyfalcon
my bro inlaws ef don't have a dip stick.
and neither does my ea.
2000 AU Wagon
naughtyfalcon is offline   Reply With Quote Multi-Quote with this Post
Old 23-03-2007, 09:24 AM   #18
ilsautomotive
Former E-Series Member
Some say a transmission service at least yearly isn't a bad thing anyway... that would be my suggestion.
ilsautomotive is offline   Reply With Quote Multi-Quote with this Post
Old 16-07-2011, 03:10 PM   #19
littleredwagon
8 pots only.
littleredwagon's Avatar
Default Re: el transmission fluid
Yeah, but how do you put the trans fluid in?
littleredwagon is offline   Reply With Quote Multi-Quote with this Post
