Old 10-01-2010, 07:36 PM   #1
bivo7
EF Falcon
bivo7's Avatar
Default v8 in escort
hey thinkin of buying a escort mk2, is it possible to fit a v8 in the bays? was hoping for a 5l winsor but could go smaller. has any one done it before or know any one or any links to someone who has?
bivo7 is offline   Reply With Quote Multi-Quote with this Post
Old 10-01-2010, 08:11 PM   #2
Fev
Fev's Avatar
Search for MD Conversions. They made a few of them before the govt outlawed them lol. Not sure about SA but you can't register them in nsw anymore. Largest engine you could fit there legally in nsw is 3L n/a or 2.5 s/c or turbo. If that helps
1992 EBII Fairmont Ghia 4.0l <---Click for the Gallery!
Insta@mooneye_ghia
White on bright red smoothies with thick whitewalls. Cruising around to some rockabilly
Fev is offline   Reply With Quote Multi-Quote with this Post
Old 11-01-2010, 04:05 PM   #3
SnoWhite
Yes, I remember a white RS2000 with the NSW plates - DMT351. It had a 351 in it. A fair bit of work required to the engine bay sheet metal.
Also the NSW branch on the Small Ford Car Club have a member with a White replica RS2000 with a V8. Contact Roy Rogers for more details if required.
SnoWhite is offline   Reply With Quote Multi-Quote with this Post
Old 11-01-2010, 04:06 PM   #4
cortina-mk1
Heavy right foot
cortina-mk1's Avatar
MD conversion fitted clevelands
and they were also blown
burnout cars
so a windsor will fit much better
cortina-mk1 is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2010, 06:59 AM   #5
BA SR FALCON
BA SR FALCON's Avatar
Default WA Laws hard as
In WA we have the worst laws for any and everything anything not factory ! But even hear the 'tec sec' run by reno markise say's going from 4cyl to 6 cyl is ok with approval,brake up grade ect ect, but going from 4 cyl to 8cyl would never be regoed hear in good old "Wait Awhile"
any one know whats the story for tassie ? mine is a 1959 P/Van
BA SR FALCON is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2010, 07:42 AM   #6
BA SR FALCON
I was told that if u V8 it u will have fun in a straight line buy nothing else, turning, stoping and ride.... GONE !
Old 31-01-2010, 03:42 PM   #7
Tony
: To get a v8 into an escort you need to find an engineer that will allow you to put an escort body on a chassis of a vehicle of similar size but with a weight over 1100kgs like a japanese ute.
Tony is offline   Reply With Quote Multi-Quote with this Post
Old 31-01-2010, 09:39 PM   #8
bivo7
EF Falcon
bivo7's Avatar
cant the frame and chassis of the escort be modified then stress and twist tested to be engineer aproved?
Old 31-01-2010, 09:56 PM   #9
Tony
RTA rules go off original weight of the vehicle so it doesn't matter what you do to an escort unless you make it a rebodied car. At least thats the NSW rules
Old 02-02-2010, 10:57 PM   #10
bivo7
EF Falcon
bivo7's Avatar
any one know anything about SA
Old 03-02-2010, 10:48 PM   #11
R0BD0G
R0BD0G's Avatar
MD conversions?
Mark Dalla'qua's green one and the red one?
http://www.youtube.com/watch?v=PLAHd_0P4qw
1628 Escort Project Thread
67.3 RWHP - Paramount Performance Dyno
DJ Automotive Tuned with proper jets
http://fordforums.com.au/showthread....4&page=1&pp=25
R0BD0G is offline   Reply With Quote Multi-Quote with this Post
Old 04-02-2010, 11:29 AM   #12
outback_ute
Ute Forum Moderator
Contributing Member
outback_ute's Avatar
bivo7 - check with Transport SA
outback_ute is offline   Reply With Quote Multi-Quote with this Post
Old 11-02-2010, 08:01 PM   #13
derkdebone
are we there yet ?
derkdebone's Avatar
had a 460 big block in a mk2 ...why? coz they said it wouldn't fit : ...although did have to make it left hand drive because of where the starter motor sits .Also had to hand make extractors. In all its not a 5 minute job but it does make for a fun car . As far as i know 302 as big as they will engineer for road use, unles you go for (VIC) street rod rego .
derkdebone is offline   Reply With Quote Multi-Quote with this Post
Old 11-02-2010, 11:46 PM   #14
bivo7
EF Falcon
bivo7's Avatar
im in sa dont really care how its registered or what its registered as i want to use it as a daily drive you recon its posible? will it have to have to engineer certificate? do you know any one i can talk to about this? transport sa said they cant help until i have the car built and lookin to reg it. but ther is no point building it if i cant drive it?
derkdebone do you have any mor pics of your build would be interested in any v8 mk2 convertions
cheers
Old 12-02-2010, 08:33 PM   #15
derkdebone
are we there yet ?
derkdebone's Avatar
Mine was only ever built for fun ,never ment to see the road .Street rod rego doesn't require engineers reports but does involve you being able to join a street rod club and each drive has to be log booked. you will need to find out your local requirements (SA) but in vic its stock 302 , no extractors , 2 barrel carb and no engine mods for engineering . also body has to be seam welded , different engineers will have different requiements as far as cross members , brakes etc but seen as they are the ones putting their names on the certificate to say its safe then i guess thats understandable . i think if i was goin to do one for road use i'd try to track down a rover v8 as theyre all alloy , small , light weight , rev hard and because theyre only 3.6 litres should require less for a report(maybe). So first thing first , find and talk to an engineer or 2
Old 14-02-2010, 07:11 PM   #16
bivo7
EF Falcon
bivo7's Avatar
thanks will do got a week off soon will ring around and see where i stand. do you have any more pics of your v8 escort
Old 15-02-2010, 02:53 PM   #17
outback_ute
Ute Forum Moderator
Contributing Member
Not sure if they have Street Rod rego in SA, and their car club/historic rego is for standard-ish cars only, so you will be looking at normal full reg.
Saw a 302 Escort at Hanging Rock on the weekend, it had a custom firewall (heater pod removed)
bivo - why not make a trip to Regency to ask your questions?
Old 15-02-2010, 07:26 PM   #18
bivo7
EF Falcon
bivo7's Avatar
do you recon they will be able to tell me or is it worth contacting the engineers first
Old 16-02-2010, 08:58 PM   #19
EASYBOSS
Matakana NZ
EASYBOSS's Avatar
Find a P96 alloy V8, heaps lighter
SOLD : BA XR8 4 Speed Auto in Mercury Silver, Bluepower CIA, Full Diffilipo Big Boy Quad System, Tune, 4.11 Diff Gears, FPV Starter Button, FPV GT Rear Spoiler, Tripod Gauges, PWR Trans Cooler. 230 RWKW's. Many thanks to Chris at Bluepower Racing Developments
Hers : F6X build #150 in Ego, Stock as a Rock, untill the warranty runs out, including the extended one.
My Work Wagon AU Futura Wagon in Gold.
On the Farm : Ford 6600 Tractor
EASYBOSS is offline   Reply With Quote Multi-Quote with this Post
Old 17-02-2010, 06:59 PM   #20
outback_ute
Ute Forum Moderator
Contributing Member
Bivo - I understand that is where all the tech guys are based so they ought to have the answers and requirements. If not they ought to at least direct you to the right place. If you have an approved engineer I'm sure they would know the ins & outs too.
Old 17-02-2010, 11:43 PM   #21
bivo7
EF Falcon
bivo7's Avatar
what is a p96 out of
Old 18-02-2010, 09:29 AM   #22
outback_ute
Ute Forum Moderator
Contributing Member
I think he means P76 V8. Could also go Rover V8 (the P76 is a larger version of this)
Old 18-02-2010, 02:03 PM   #23
cortina-mk1
Heavy right foot
this was at hanging rock on sunday
Old 18-02-2010, 02:35 PM   #24
Fev
Fev's Avatar
Thats AWESOME!! Not a fan of the wheels but the rest is damn awesome!
If you see that guy again tell him Street Fords Magazine is looking for him for a feature hahah
Insta@mooneye_ghia
