Old 24-03-2009, 10:59 AM   #1
FocusSr
Question Ford Telstar question
i have a 1993 ford telstar tx5 ghia, It has the 2.5 v6 in it its 3 speed auto
and everytime like you come up to a red light to fast and you hit the brake, It stalls it will just cut out accessorie lights will come on you will have to put it in park or neutral and restart, what could be causing this problem the engine has good power does'nt lack transmission isnt sluggish or anything its all good but if you hit the brake to hard it will stall.
FocusSr is offline   Reply With Quote Multi-Quote with this Post
Old 24-03-2009, 10:13 PM   #2
XR Martin
XR Martin's Avatar
Sounds like a vacuum issue perhaps? Maybe a brake booster leak?
Tried a heavy stop without using the foot brake? Use the trans to engine brake and also use the handbrake
PS Its actually a four speed auto
2004 BA wagon RTV project.
Old 24-03-2009, 10:24 PM   #3
XR Martin
XR Martin's Avatar
You could also try heavy foot braking in [N] with you holding the revs at 1000rpm, I doubt it would stall as the throttle will be open allowing air in.
How does it idle normally? Could also be an Idle Speed controller issue I guess.
Old 25-03-2009, 01:31 AM   #4
dirty hands
Over Thinker
dirty hands's Avatar
could be a faulty torque converter
needs a stall test done on it
what about an automatic service .....needs one every year
My car goes Brumm Brumm
Old 25-03-2009, 01:39 AM   #5
SAMSABU
Default FocusSr
Your problem could be caused by a couple of things.
1...Base idle speed adjusted too low.
2...Throttle position sensor incorrectly adjusted or worn.
3...Idle step motor sticky or worn.
Check owners manual for recomended idle speed.
The others need to be checked by a Mechanic.
One last thing.....Make certain the motor is not over filled with oil.
Overfilled on heavy braking would cause oil surge and stalling.
Hope this is a help.........
SAMSABU is offline   Reply With Quote Multi-Quote with this Post
Old 26-03-2009, 10:53 PM   #6
FocusSr
thanks guys ill take all this in
