14-03-2019, 11:07 PM | #1 | ||
Mainly in case someone wonders how something should look, or how it goes together.
The steel brace tube or spine of it all. Vacuum reservoir hidden in the steel brace tube. The two halves of the lower section, and combined. The top pad. White mess is a 2K acrylic glue made for spa repairs. Bonds nicely to ABS. I’ve also included a photo of where the centre braceback rod passes through the ducting, it was made with foam donut seals but a pair of closely abutted foam strips works as well. I’ll add similar of the harness when that’s reinstated. |
5 users like this post: |
15-03-2019, 03:02 AM | #2 | ||
All Bran = Regular Member
You ought to get a hold of a mod and see if it can be added to the Tech Resources section.
15-03-2019, 04:51 PM | #3 | ||
Thanks for the pics.
Can you tell me if the black hex fitting where the hose connects to the reservoir looks like it unscrews ? I had the hose brake of below the black hex nut, and need to figure out how to re-attach ? |
15-03-2019, 06:21 PM | #4 | ||
I pulled the barbed end of the black fitting, out of the clear piece to re-tape the three fixing clips. Didn’t think to see if it was a thread the other end (gut feeling is, it’s just another barb).
15-03-2019, 07:36 PM | #5 | ||
Next upgraded Mk1 Leopard
Interesting info
UK
