03-11-2019, 04:07 PM | #1 | ||
These AU falcons are a bugger to get up onto stands at the front, mine is anyway.
So I was thinking about scissor jacks, they are great and safe to change a wheel etc, but not if you want to work under the car on suspension etc. Why, not strong enough or might unwind and lower the thingy ? I have a very strong wind up model capable of supporting a couple of tonnes, I could get another one and have two. When they are wound up the long screw bolt protrudes out of the frame, so if a nut was done up on that bolt back to the frame it could be wound up but not down. A larger square plate could be welded to the base so that it will not tip. Should be a safe cheap stand. Your views. |
03-11-2019, 06:55 PM | #2 | ||
Former BTIKD
NO jack is a substitute for good ramps or jack stands
03-11-2019, 07:11 PM | #3 | |||
64 Deluxe 4 door
XM Deluxe FG XR50 BA Pursuit Ute |
03-11-2019, 07:16 PM | #4 | ||
Limited supply
03-11-2019, 07:26 PM | #5 | ||
Every single part of a jack is a potential failure point, any one of which would be catastrophic. A stand or ramp is a simple thing with less points of failure. They're also much more stable than a jack.
03-11-2019, 08:03 PM | #6 | ||
I should have explained a bit better.
If I get under it to work on steering, knuckles, rubber etc I work it up onto ramps to get under it. But in the next few weeks I will be replacing coils and shocks with I think Kings. I just need to get it up via the body jacking point on a stand and work beside it not under it. With my crook back I don't want to bugger around trying to get under it with a trolley jack under the cross member. The rear is no problem because it is a beam axle. I think my scissor jack with a lock nut will be okay. My wife died in 2010. |
03-11-2019, 08:06 PM | #7 | |||
Former BTIKD
3 users like this post: |
03-11-2019, 08:25 PM | #8 | |||
#neuteredlyfe
As others have said, do not rely on jacks to support a car while working on it. Sliding a couple of stands under the front of it is very easy, even with a sore back. Jack it up, position the stands and let the car onto them. If your back is that sore that you can't slide a couple of stands under the car then I suggest that your back may not cope with replacing the shocks and coils. It does not matter if you are working under or beside it, when cars fall off jacks they tend to move sideways and not simply just straight down to the floor - and Murphy's Law will dictate that it will fall towards you. |
8 users like this post: |
03-11-2019, 10:42 PM | #9 | |||
so if it does fall your not going to move in a hurry and even if you did id guarantee it all be over before you knew it was on your legs
yes still (as money n time permit) doing the rebuilding the zh fairlane with a clevo 400m 4v heads injected whipple blown with aode 4 speed trans to a 9" ....... we'll get there eventually just remember don't be afraid to try something new. Remember, amateurs built the Ark...Professionals built the Titanic! I have taken up meditation... at least it's better than sitting around doing nothing !! |
2 users like this post: |
04-11-2019, 11:32 AM | #10 | ||
No matter how many jacks or stands are under a vehicle, I do not allow my students to get under a car without a tyre stack under either side. Usually two Falcon size wheels, or more...
04-11-2019, 11:37 AM | #11 | ||
Have seen a scissor jack bend/fold-over and collapse ..... really quickly.
I use stands all of the time just for safety sake.
07-11-2019, 07:47 PM | #12 | ||
2003 BA Falcon XT
If you read this.... or anyone else.
I have a cheap hydraulic jack from supercheap I bought in 2013... still works fine. The 1400kg one. Anyway the metal jacking plate is too small and would crush through the chassis rail.... so I use wooden off cuts and place that on the metal part of the jack, then jack the car up from the chassis rails. NOT THE SILLS where a scissor jack would go. I do one side at a time and slide jack under. Also handy to have a paver under tyres to give you a bit more room to work with. Happy to post picture if it would help people and discourage them from using scissor jacks. For the rear I jack off the suspension frame in front of the diff. I don't think scissor jack and safety can be used in the same sentence.
2003 BA Ford Falcon XT IMPCO LPG Vapour Injection. DETAILING Meguiar's NXT Car Wash Collonite #845 Insulator Wax Bowden's Own Happy Ending & Fully Slick Chemtech CT-18 Truck Wash (Wheels & Chassis) Bowden's Own Wheely Clean & Tyre Sheen Bowden's Own Three Way Paint Decontamination Spray OILS AND FILTERS Nulon Full Synthetic 10w-40 Nulon Long Life Coolant Ryco Oil & Air Filters My Instagram Account: @ba_falcon2003
07-11-2019, 08:54 PM | #13 | ||
The locknut idea isnt terrible, but still in my opinion not for getting under a car. Added safety for changing a wheel maybe. The footprint on the ground of a scissor jack is also a lot smaller. Jack stands arent too expensive. Like all safety gear dont go for the cheapest. Ive heard of failures with the ratchet style. I prefer to use my lock pin style stands getting under a car. My ramps, i cant get my bf up without munting the bumper. I could easily get the ranger up them, but i dont need to work on that. I got a cheap deal at sca for a 2500kg trolley jack and pin type stands that seem to be reasonable compared to the at the time cheap stands they also sold for $50 per pair which didnt exactly inspire confidence. You can paint a thin weld, but its still a thin weld. Yes i do have some of the cheap stands under my boat at the moment with my good ones as i need to work on the trailer axle, but 4 cheap stands and my better 2 holding up 1600kgs, i think thats pretty safe. And also, a hydraulic trolley jack will be much easier on the back pumping it up.
