Old 19-12-2017, 04:35 PM   #1
goldcoast
Default Ford Fiesta 02/2006 Timing Belt
I am about to change the timing belt on a 02/2006 Ford Fiesta manual. German Assembled model with 163,000km on the clock. I have changed timing belts on toyotas and hondas before and yes I know it can be a pain.
Any constructive tips about the job- tensioners etc. ?
Are there any special tools required?
Is there anything else to look for or be aware of?
It is getting a kind of major service. I will be changing the two outside belts, heater hoses, radiator coolant and radiator hoses, air filter, and oil change at the same time.
Thanks
William
goldcoast is offline   Reply With Quote Multi-Quote with this Post
Old 08-02-2018, 01:23 AM   #2
cobrin
Challenge Accepted!
cobrin's Avatar
Default Re: Ford Fiesta 02/2006 Timing Belt
have you done the belt change yet?
Undecided replacement...
[SOLD] -2009 MB Mondeo Zetec TDCI- [SOLD]
cobrin is offline   Reply With Quote Multi-Quote with this Post
Old 08-02-2018, 10:12 AM   #3
goldcoast
No I have not done the belt change yet. I have the timing belt and 2 serpentine belts.
The car has done 91,000 km. Should I change the tensioner?
It looks like i need a flat bar to lock the cams and a long 10mm bolt to lock the crank at top dead center. Also there is not much room to get the timing cover and crank pulley off
I'm wondering if I have to drop the K Frame? I do not have a lift. I am doing it on the driveway tomorrow.
Will
