Old 14-01-2021, 05:37 PM   #3481
wodahs
wodahs's Avatar
Default Re: All things Solar (merged threads)
Originally Posted by roKWiz View Post
Still see COPE trucks. Wasn't it called COPE sensitive at the time.
not in WA we use to do this and stuffs ranging from xray equip/cat scans to pianos to ... sensetive stuff
and ended up selling to cope , the then owner became the WA manager and his son a mate of mine is now running this depot i believe
think the companies name back then was chalange transport
yes still (as money n time permit) doing the
rebuilding the zh fairlane with a clevo 400m 4v heads injected whipple blown with aode 4 speed trans to a 9" ....... we'll get there eventually
just remember don't be afraid to try something new.
Remember, amateurs built the Ark...Professionals built the Titanic!
I have taken up meditation... at least it's better than sitting around doing nothing !!
wodahs is offline   Reply With Quote Multi-Quote with this Post
Old 29-06-2022, 12:37 PM   #3482
Being the solar thread…
For a dedicated, compliant residential enclosure to house a solar charge controller and changeover switch, do I need the “NSW standard” 600x600x250 box?
In cavity brickwork is HD conduit required for lead-ins? Or is the brick cavity itself considered sufficient for internal wiring?
Old 29-06-2022, 09:03 PM   #3483
zilo
BANNED
zilo's Avatar
In Tasmania it goes into the standard switchboard since the changeover switch needs access to the mains supply intercept to the house.
We use a standard generator changeover switch, pole 1 up, center off, pole two down.
Brick cavity should be fine if it is weather sealed...IMHO
I used an electrician even though it's a no brainer to install, suggest you do the same.
Please press the "Like" button if you enjoy my posts.
(It's the red triangle with exclamation mark on the left)
zilo is offline   Reply With Quote Multi-Quote with this Post
Old 29-06-2022, 10:21 PM   #3484
I will use a sparky for the actual wiring (I’ve been warning him, the longer he avoids me the bigger the job gets ), but I’ll set the wall box and it’s neater, less rushed when I do it. Tas wall boxes are a different size to NSW, taller and a bit narrower. Ideally if a complying enclosure was 450-500 square by 250 it should suffice. I haven’t seen a dimensioned diagram of a solar charge controller and specific breakers for ≅15kW output.
Old 01-07-2022, 09:34 AM   #3485
zilo
BANNED
zilo's Avatar
That is a big charge controller 15kw?
what are you using?
Old 01-07-2022, 09:44 AM   #3486
I haven’t spec’d anything yet.
It’s a slightly arbitrary number but the long game is to take power completely off-grid in a 75 year old suburban house, including a sizeable air-con (or as people say in Tasmania, heat pump). I want to be done in the roof before summer; all services plus insulation.
Old 01-07-2022, 07:00 PM   #3487
zilo
BANNED
zilo's Avatar
You will not find a charge controller with that spec.
I have done a few off grid setups, would you like a shopping list?
