Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > Bendix
Bendix BENDIX Ė Put your foot down with confidence
Old 08-05-2019, 07:12 PM   #1
motorculture
motorculture's Avatar
Default Changes to Brembo Caliper brake pads from Bendix
This Brembo caliper has been fitted to many vehicles, and has had many disc pads with different wear sensor, groove and chamfer configurations to mitigate any noise.
All friction causes vibrations, and most brake and suspension components have natural frequency they vibrate at. If the Pad or Caliperís natural vibration frequency matches the vibration frequency coming from the friction surface it becomes an audible noise.
The standard approach to stop noise was by adding a noise-dampening shim on the back. Recently another approach was created, weights were added to the pad to change its natural vibration frequency, so DB2358 was developed from the original DB1678.
With the introduction of DB2358 it was found that the large round weights could come into contact with the inside of the wheel rim on some wheel designs. To rectify this the shape of the weights was modified so that they donít protrude from the caliper as much.
We are reintroducing the DB2358 with the modified weight design.
Follow Bendix Brakes on Facebook HERE.
To learn more about the Bendix Brakes range of products visit: www.bendix.com.au
Automotive social media http://motorculture.com.au or call us on 02 9418 9008
For some daily car culture check out http://zengarage.com.au/
motorculture is offline   Reply With Quote Multi-Quote with this Post
Old 08-05-2019, 07:21 PM   #2
PHANTMXR6
It's not an FG MKI.......
PHANTMXR6's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Willing to help out with useful advice in the technical areas of the forum.
Smile Re: Changes to Brembo Caliper brake pads from Bendix
No offering for Falcons?
06/08 Manual FG XR6T. Not an FG1 or MKI, an FG...
Want to know how to do an A Service for an FG XR6T?
Look in this http://fordforums.com.au/showthread.php?t=11339404
Thinking of oil sampling your engine?
Have a look at this trend http://fordforums.com.au/showthread....ght=oil+sample
PHANTMXR6 is offline   Reply With Quote Multi-Quote with this Post
Thread Tools
Display Modes
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
