Go Back   Australian Ford Forums > The Sales Yard > Spare Parts and Other Accessory Items > Cleveland Parts Section
Cleveland Parts Section Specifically for parts and other sundry items related to the Cleveland engine models.
Old 27-02-2016, 09:27 PM   #1
something wrong
something wrong's Avatar
Default (NSW Parra area) Cleveland Parts (conversion Set)
$500 Ono for the lot.
Cleveland XD Black Block Electronic Distributor, new bushes in shaft was working when pulled out 2 yrs ago.
1 x XC Cleveland Block Standard Bore Rusty will need acid bath and bore/ machining.
1 x XC Cleveland block 030 same need machining and clean
Roll Master blue series double row timing chain and gears (3 key way settings)
Chassis mounts from XD to suit Cleveland, may suit other models as well.
XD Cleveland engine mounts brand new in packets
AFS8347PT full gasket kit (Plus a few spare gaskets)
Auto Flywheel
302c rods
Closed chambered heads
Mellings oil pump drive rod Is84a
Drop me. PM to discuss
I also
Have a bunch of XD parts as well, mainly trims and lights and bits and pieces.
something wrong is offline   Reply With Quote Multi-Quote with this Post
Old 28-02-2016, 04:56 PM   #2
something wrong
Some photos to comply with site rules:
Old 17-03-2016, 11:06 PM   #3
something wrong
Old 30-03-2016, 07:42 PM   #4
something wrong
Revised price $410 Ono
Old 04-04-2016, 06:51 PM   #5
something wrong
$380?
Old 29-04-2016, 10:44 PM   #6
something wrong
$350 Ono
Old 06-05-2016, 01:44 PM   #7
something wrong
Default Re: (NSW Parra area) Cleveland Parts (conversion Set)
1 x XC Cleveland Block Standard Bore. Outside of block Rusty will need acid bath and bore/ machining, no major scores or lips inside the bores, 010 should be all thats needed
1 x XC Cleveland block 030 same need machining and clean, same as above
$50 (Based on the fact they will need checking and machine work)
Old 09-05-2016, 06:44 PM   #8
ford-speed
Hi Buddy, are you wanting only $50 for 2 clevo blocks? Maybe its a typo?
I'm keen at $50.
ford-speed is offline   Reply With Quote Multi-Quote with this Post
Old 14-05-2016, 11:53 PM   #9
something wrong
Yep happy to get $50 as they need to be checked over and tested prior to any work as I have not used or had them checked as I bought them off EBay 8yrs ago and they have been sitting ever since in my garage.
Old 18-05-2016, 10:51 PM   #10
something wrong
Blocks sold to Ford-Speed
Old 06-06-2016, 12:26 AM   #11
daddyofemrys
Hi would u have a ford 4 barrel air cleaner
daddyofemrys is offline   Reply With Quote Multi-Quote with this Post
Old 06-06-2016, 06:55 PM   #12
ford-speed
No sorry, i have a couple of old 14 chrome ones witrh dents and rust but on OE ones.
Old 13-06-2016, 03:46 PM   #13
zj 300
What trims for XD do you have?
zj 300 is offline   Reply With Quote Multi-Quote with this Post
Old 20-06-2016, 10:33 PM   #14
something wrong
Dash top panel, driprail side chrome trims, rear screen chrome trims, some dash side speaker grilles, steering column covers, glove box lids.
Sorry no aircleaner
Old 27-09-2016, 10:23 PM   #15
FGII-XR6
FGII-XR6's Avatar
Do you still have the heads if so how much?
[SIGPIC][/SIGPIC]
Rides:
Old 18-11-2016, 09:25 AM   #16
mltezr
how much for the xd engine mounts if you still have them?
mltezr is offline   Reply With Quote Multi-Quote with this Post
Old 02-03-2017, 02:03 PM   #17
something wrong
Hi Just saw your Post, I still have the mounts, did you want the chassis mounts or the rubber engine mounts
Rubber engine mounts $25 the pair
Chassis Mounts $40 the pair
Cyl Heads went in the last council clean up
The other stuff still available, prefer bulk lot to clear it out rather than bits and pieces.
No Postage as i don't have boxes or bubble wrap ect and its a pain getting to the Post Office with my work.
Thread Tools
Display Modes
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
