Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > Pit Lane Performance
Pit Lane Performance Pit Lane Performance, tuning for power and satisfaction. Website Link
Old 04-08-2014, 01:27 PM   #1
ratter
ratter's Avatar
Default BF and FG diff bushes $599 supplied and fitted
Pit Lane are now offering to replace the troublesome BF and FG Falcon Sedan differential side and rear bushes for $599 using SuperPro Comfort bushes.
That's correct, $599 to supply and fit, that's less than some others are charging just for the labour to do the job.
Superpro bushes come with a lifetime warranty on the parts
We are able to do other models and use different bushes as requested but price may vary
ratter is online now   Reply With Quote Multi-Quote with this Post
6 users like this post:
Old 30-09-2014, 08:32 PM   #2
MISSN2
MISSN2's Avatar
Default Re: BF and FG diff bushes $599 supplied and fitted
What about the Fg utes?
New: FG MKII Limited Ed XR6T ute 6 Speed Man in Swift, Stock for now
Old: BA Xt with a 3V and 5 Speed Man Silhouette 220rwkw.
MISSN2 is offline   Reply With Quote Multi-Quote with this Post
Old 30-09-2014, 09:27 PM   #3
ratter
ratter's Avatar
what about them?
Old 02-10-2014, 12:27 PM   #4
Trump
bitch lasagne
Trump's Avatar
If your diff bushes are gone, get on this people, this is a bargain!
Scaled Business Solutions
For Your Small Business IT Needs
Trump is offline   Reply With Quote Multi-Quote with this Post
Old 04-10-2014, 06:40 PM   #5
EX__Taxi
LPG Power , Cheap to run
EX__Taxi's Avatar
looking to get this done
once the car its tuned :P
2004 BA Futura in RAPID YELLOW
the car gone
http://www.fordforums.com.au/showthread.php?t=11421216
EX__Taxi is offline   Reply With Quote Multi-Quote with this Post
Old 21-01-2015, 10:44 PM   #6
Blem
POWER Portress
Blem's Avatar
Good pricing Mick.
Group buy on ID injectors this year ?
FGF6 ...... factory stock tune/donk, Process West stepped interooler & cooler piping, k&n panel filter & Shockworks coil overs.
Sitting on Venom 100 cell cat.
Next purchase 1000 injectors & hello Bruce
Blem is offline   Reply With Quote Multi-Quote with this Post
Old 21-01-2015, 11:03 PM   #7
ratter
ratter's Avatar
thanks, but supplier of ID's will not discount even for large purchases
Old 13-05-2015, 11:56 AM   #8
STINKY NINJA
Ratter,have you had any superpro comfort bushes fail yet?
Im tossing up between comforts and the polyelast bushes for my g6et,what would you recommend and would rwkw levels affect your choice?
Cheers Shannon
STINKY NINJA is offline   Reply With Quote Multi-Quote with this Post
Old 13-05-2015, 12:48 PM   #9
ratter
ratter's Avatar
we have seen 1 side bush get damaged but it appears the bolt broke and caused the damage, it was in a high 400 rwkw car.
your decision needs to be based on how you want the car to feel
Old 13-05-2015, 01:12 PM   #10
STINKY NINJA
I want bushes that last alot longer than factory bushes with the reliabiity to floor it when i see fit without the worry of bushes failing,a bit more nvh would be ok for the sake of reliability,car wont be raced and will most likely never see above 280-300rwkw max.
I guess i want it to feel almost factory.
By the sounds of it the comfort bushes are more than strong enough for what i want so no real need to get polyelast bushes unless the polyelast give less nvh,only reason id go for them.
Old 13-05-2015, 02:21 PM   #11
ratter
ratter's Avatar
the superpro comfort fit your requirements
Old 13-05-2015, 03:32 PM   #12
STINKY NINJA
Thanks for your advice Ratter.
i know the newer style side comforts have smaller voids,does the rear also have smaller voids?
Is it the same part number as the old kit?
Old 15-05-2015, 01:31 PM   #13
WindsorXR
FGII XR6, Focus Sport, XR
WindsorXR's Avatar
Is this deal still on? Need my bushes fixed in BA XR8. They are screwed.
Living Ford dreams
2011 Purple FGII XR6
2016 LZ Focus Sport
BA XR8 Build Thread (SOLD)
1966 XR Falcon Build Thread
WindsorXR is offline   Reply With Quote Multi-Quote with this Post
Old 15-05-2015, 02:19 PM   #14
ratter
ratter's Avatar
yes mate, due to popularity we have kept this deal running
Old 15-05-2015, 08:58 PM   #15
newi
Hey guys. I am starting to get some clunking and knocking from the rear of my FG. Seems to happen when going over bumps - especially when turning and you go around a bit of a bump.
Is this a sign of the diff bushes needing replacement?
newi is offline   Reply With Quote Multi-Quote with this Post
Old 15-05-2015, 09:02 PM   #16
ratter
ratter's Avatar
although they can give noises as you described, normally diff bushes are noisy when on and off the accelerator
Old 15-05-2015, 09:19 PM   #17
newi
Interesting - is there anything else that commonly goes wrong that could be causing this?
Either way - I should get it checked.
Old 15-05-2015, 09:36 PM   #18
ratter
ratter's Avatar
there are quite a few areas that can give that sort of symptom you are best getting someone to actually look at the car to see where it's coming from
Old 01-06-2015, 04:14 PM   #19
JGP
Another thanks to Pitlane for this deal, got this done and car feels better. Tbh I was expecting more nvh as I have these bushes on my territory and at speed I can hear the whine in that(not that it bothers me). The xr feels great, if your thinking of doing it get it done and for the price at Micks cant go wrong.
-BF2 XR6T 300+rwkw(PitLane),Leather,premo sound. Plazmaman IC + hot & cold side,Walbro fuel pump,Hi energy intake, DBA T3 & Akebono ProACT all round,Whiteline sway bars, nolathane bushes, 100 cell cat,deka 60 injectors,built tailshaft + billet cv,ZF + PWR exchanger + braided lines, superpro diff bushes, earls turbo oil feed
-2015 CX9 Grand Tourer AWD
-2016 SRT8
JGP is offline   Reply With Quote Multi-Quote with this Post
Old 01-06-2015, 04:51 PM   #20
Vegetable
Also had this done and it was well worth it... hard acceleration is fun again not painful
Vegetable is offline   Reply With Quote Multi-Quote with this Post
Old 17-08-2015, 02:52 PM   #21
Wolfinsheepsclothing
preying on lions
Wolfinsheepsclothing's Avatar
Hi mick I'm looking in to getting the diff bushes done on my fg gs 315, I have about 350rwkw's and are considering the super-pro comfort bushes, question will these bushes be ok, I would jump at the deal you are offering but are located in NZ, could you give the part numbers for these bushes and should there be anything else I should do while the rear end is out? Sorry for all the questions, any help will be appreciated thanks Geoff
2011 FPV GS315 s/c nitro- #158, -355rwkw's tune, BMC airfilter, KPM exhaust, Breather filters, Herrod tail-shaft, 6/4 Brembo's, Koni shocks, King springs - pb 12.4 @ 117mph; SOLD.; - New toy '15 Dyna Wide-Glide SOLD: now waiting on 2020 Lowrider
Wolfinsheepsclothing is offline   Reply With Quote Multi-Quote with this Post
Old 17-08-2015, 03:10 PM   #22
ratter
ratter's Avatar
we have these in cars making more power than what you are talking but whether ideal or not is really dependent on what you want from the car, we see many cars that do not drive very nice at all due to some mods but the owners are happy with them
Kit190K
Old 17-08-2015, 03:17 PM   #23
preying on lions
Thanks for your quick reply, basically I want a step up from std, but want it to feel like stock if you know what I mean, cheers
Old 17-08-2015, 04:23 PM   #24
ratter
ratter's Avatar
if you are real fussy with your car, you may notice a little more NVH, we have fitted probably over 30 sets and only 1 customer has commented on them negatively
Old 17-08-2015, 05:32 PM   #25
Vegetable
Pitlane did this for me and it made a massive improvement to my gs. Rear end used to clunk about a lot but is now brilliant. Also i cannot say i have noticed any extra nvh at all. If anything its quieter because no thunks anymore.
Old 04-09-2015, 10:02 AM   #26
Migna
Migna's Avatar
Hi ratter, everyone has reported how great the superpro bushes are, but one thing that is never really mentioned is how long they last.
In your experience, how many kms should the average driver expect out of these bushes (no drag/circuit/thrashing)? I know its one of those "how long is a piece of string" questions but going from your experience with these bushes what would you expect to get out of them?
Migna
Ride
2010 Silver FG XR50 Turbo
Migna is offline   Reply With Quote Multi-Quote with this Post
Old 02-12-2015, 08:15 PM   #27
AJ09
Hi,
Is this deal for FG bushes still available?
AJ09 is offline   Reply With Quote Multi-Quote with this Post
Old 02-12-2015, 09:09 PM   #28
ratter
ratter's Avatar
Unfortunately it looks like no, we can not source the Superpro Comfort bushes any more as they have been replaced and the new ones are $50 dearer, We are re-assessing prices but it looks like $649 is the new price
Old 02-12-2015, 09:27 PM   #29
AJ09
Ok, I began to worry when I read the word "no" in your post..
Even at $649 I think it's a good deal, the knocking is driving me mad!
Would you mind letting me know when pricing is finalized so I can book in to have the work done.
Old 02-12-2015, 09:29 PM   #30
graham_h
graham_h's Avatar
Any issues fitting a nolathane one ? Most shops I've spoke to wont do them because the bolt has to be cut to length (I've already got the part)
graham_h is offline   Reply With Quote Multi-Quote with this Post
Thread Tools
Display Modes
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
