Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > Bendix
Bendix BENDIX Put your foot down with confidence
Old 27-02-2019, 02:42 AM   #1
motorculture
motorculture's Avatar
Default Uneven wear on new brake pads
Cause: After fitting new brake pads, customer came back for a check up and we found huge uneven pad wear.
Solution: Uneven pad wear is often a caliper problem, caused by faulty seals, sticking or bent slide pins. Overhaul the calipers on that axle. Ensure you have used the correct lubricant, such as Bendix Ceramasil Brake Parts Lubricant on the right component
Follow Bendix Brakes on Facebook HERE.
To learn more about the Bendix Brakes range of products visit: www.bendix.com.au
Automotive social media http://motorculture.com.au or call us on 02 9418 9008
For some daily car culture check out http://zengarage.com.au/
motorculture is offline   Reply With Quote Multi-Quote with this Post
Thread Tools
Display Modes
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
