Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > Crescent Motor Sport
Crescent Motor Sport Specialising in all Early and Late model Ford Performance. Website Link
Old 17-05-2013, 06:08 PM   #1
Franco Cozzo
Misanthropist
Franco Cozzo's Avatar
Default CMS Stage 3 head 2a cam
Hey guys, I bought a CMS Stage 3 head with a stage 2a cam and she idles a bit rough.
It revs up and down every few seconds from 750 to 1000 then back down, then it will do it again maybe 10 seconds or so later.
The car has been tuned, and it has a new idle speed control valve and map sensor.
Do I need any mods to anything?
Thanks much.
Old 20-05-2013, 08:20 AM   #2
joe@cms
Default Re: CMS Stage 3 head 2a cam
Hi Mate,
Was the car tuned with the head and cam on it or before?
joe@cms is offline   Reply With Quote Multi-Quote with this Post
Old 20-05-2013, 12:23 PM   #3
Franco Cozzo
Misanthropist
With the head and cam
Old 20-05-2013, 01:03 PM   #4
joe@cms
Ok, I'm guessing it was done with an eliminator chip or similar, That being the case the first thing you need to do is remove the chip and see how it runs without it as the 2a cam was designed to work and idle nicely with the factory ecu!
If it still hunts at idle then you need to check things like your TPS voltages as this is the main cause of hunting problems and go from there.
Thanks.
Old 27-05-2013, 10:20 PM   #5
Franco Cozzo
Misanthropist
Thanks.
Thanks mate, was doing it even without the chip, its tuned with a TI Performance J3, to run on 98.
I'l check out the TPS voltages, its on the throttle body right?
Old 28-05-2013, 08:26 AM   #6
joe@cms
Yes mate its on the side of the throttle body, Another thing you can look at too is the MAP sensor as that can also cause over fuelling etc.
Cheers.
Old 28-05-2013, 04:56 PM   #7
Franco Cozzo
Misanthropist
Cheers.
Thanks Joe, I just recently replaced the map sensor, I'll check resistance values and voltages, most likely its something simple
Old 25-06-2013, 07:10 PM   #8
Franco Cozzo
Misanthropist
Hey Joe, I'm going ahead with a bottom end rebuild, is this head and cam package suitable for a mild forced induction setup? I'm looking no more than 200KW at the rears.
Old 25-06-2013, 10:11 PM   #9
joe@cms
yes that will be fine, we've had & other guys as well with the same head & cam combo (depending on the rest of the hareware) over 220 rwkw on low boost
cheers
joe
Old 26-06-2013, 05:48 PM   #10
Franco Cozzo
Misanthropist
I'm looking to keep it under 200KW at the rears, could we achieve that limit through tuning?
Old 27-06-2013, 08:25 AM   #11
joe@cms
This can definately be acheived through the tune, as we can keep the boost level low and through other adjustments keep the power level at where you would like it to be.
Thanks.
Old 08-07-2013, 11:18 PM   #12
Franco Cozzo
Misanthropist
Thanks Joe, do these packages effect compression ratio by any chance?
I'm only pushing 125psi across all 6 cylinders with an AU Falcon head gasket, I think my rings are rooted.
Thanks much.
Old 09-07-2013, 08:29 AM   #13
joe@cms
When the heads are first installed they can tend to bump up the comp slightly, So if the engine has a few km's on it the rings probably are starting to suffer a bit.
Thanks.
Thread Tools
Display Modes
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
