Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > KPM Motorsport
KPM Motorsport Leading BA-FG Performance Development Adelaide/Australia. Website Link
Old 03-03-2016, 10:42 AM   #1
KPM Motorsport
Home of Mustang in Aus.
KPM Motorsport's Avatar
Default FG-FGX XR8 Intercooler Now $3999!!
The original and still the best cooler available for your
FG-FGX
5.0 S/C Falcon
GS, GT, GT-P, GT-F
is now $3999.
Available Australia and New Zealand wide direct from Streetfighter Specialist Workshops or direct from Streetfighter.
08 82999 998
orders@streetfighter.net.au
http://streetfighter.net.au/ford/contacts/
Streetfighter Specialist Workshops exclusive 3 Year Driveline Warranty
New Zealand CTB Performance N.T. Atic Performance A.C.T. Roadway Mufflers New South Wales City Performance Centre, Rapid Automotive, Tunehouse, Streamline Auto
Queensland Dyno-Link, Insane Performance, Hunter Automotive
Elite Automotive, AHT Performance Victoria , Pitlane , BPR
Western Australia
Pro-Auto South Australia KPM Motorsport Tasmania Gowans Performance and Tuning
KPM Motorsport is offline   Reply With Quote Multi-Quote with this Post
Old 07-03-2016, 03:56 PM   #2
geobar
Default Re: FG-FGX XR8 Intercooler Now $3999!!
Hey Dave,
Are you able to detail the fix for those who have FGX XR8's with the cooler hitting the bonnet?
geobar is offline   Reply With Quote Multi-Quote with this Post
Old 07-03-2016, 06:17 PM   #3
mitelsx2000
mitelsx2000's Avatar
Originally Posted by geobar View Post
Hey Dave,
Also is there an issue with FG1 running these stage-2 intercoolers?
None that we have ever heard of.
The difference with the XR8 bonnet is less clearance to start with and possibly the inconsistency of bonnet heights.
The FG1s have much more bonnet clearance.
Current ride: 2011 FPV GTE colour Edge 6-speed Auto, Build #019
BMC Twin air filter, street fighter oil breathers, Window tints & paint protection. CTB Tuned 364 rwKW
Previous ride: XR8 Black Lux pack 2004
Daily ride to work Fiesta trend 2017
mitelsx2000 is offline   Reply With Quote Multi-Quote with this Post
Old 07-03-2016, 07:04 PM   #4
KPM Motorsport
Hey Dave,
The rubbing on some vehicles is ever so light and only needs several mms to resolve.
We are finding the best method is 6mm Inserts on the subframe to lower the engine slightly.
5 min Job.
or
Ensure you use the KPM 500 Plate supplied. When fitting cut the rubber under the plate only half way up. This allows the plate to sit an extra 2-3 mm lower.
5min Job
Contact me if you need further clarification.
Western Australia
Old 08-03-2016, 12:13 PM   #5
ray351
I wish the so called 6mm inserts came with my kit, so as I would not have to look at the 2 dints on the underside of my bonnet every time I have to drain my oil separators!
ray351 is offline   Reply With Quote Multi-Quote with this Post
Old 08-03-2016, 01:54 PM   #6
KPM Motorsport
Hi Ray
Our apologies, this problem has only emerged lately as we believe bonnet spacing may not be the same on all new FG XR8 Falcons.
I am happy to send you some inserts and direct you to the suitable workshop without charge if you wish
p.s All kits will now have the 6mm inserts added.
Kind Regards
David
08 82999 998
david@kpmmotorsport.com.au
Western Australia
Old 08-03-2016, 03:15 PM   #7
geobar
Hey David,
How likely will option 2 (Ensure you use the KPM 500 Plate supplied. When fitting cut the rubber under the plate only half way up. This allows the plate to sit an extra 2-3 mm lower.) Resolve the issue?
I know 6mm is not a lot but could lowering the sub frame cause other issues with the dynamics of the car?
Old 08-03-2016, 05:56 PM   #8
KPM Motorsport
I have no concerns re inserting 6mm inserts.
We have tried it on a car recently and all perfect.
If you are not rubbing , I suspect you will be fine.
Cutting the rubber may be a good to gain a further 2-3mm.
Western Australia
Old 03-04-2016, 07:37 PM   #9
1sikxt
351c
Do you need a custom tune or can car run on standard tune? Just ordered a sprint and would like to leave a standard tune
ba xr6 5sp manaul
xt fairmont original v8 medium aqua
1sikxt is offline   Reply With Quote Multi-Quote with this Post
Old 04-04-2016, 12:29 PM   #10
KPM Motorsport
No tune needed. As you say, you can leave the standard tune perfectly.
Western Australia
Old 05-05-2016, 11:05 AM   #11
KPM Motorsport
Hey David,
Not at all.
We now supply the 6mm spacers in every FGX kit. The FG models do not require it.
Western Australia
Old 04-01-2017, 09:38 AM   #12
KPM Motorsport
We will continue running this price for the 2017 summer season.
Western Australia
Old 20-02-2018, 09:00 AM   #13
Triplex.r8
FGX manual
Triplex.r8's Avatar
Hi Dave, I want to fit the bigger cooler to my FGX XR8. The one with with the sandwich plate and no drilling req'd. Have a few questions...
1. I would like to keep the stock 'BOSS 335' plate so reading this thread I need the 6mm spacers. Can you please explain what these spacers are? I see the subframe is mounted on ~6inch studs so the whole subframe would need to be dropped 6inchs + to get the spacers on. Wouldn't this be more than a 5 min job?
2. Can the sandwich plate be provided without the 'streetfighter' engraving on the front? As I want to keep the original look as much as possible.
Any help with my questions would be greatly appreciated, thank you.
Triplex.r8 is offline   Reply With Quote Multi-Quote with this Post
Old 20-02-2018, 10:49 AM   #14
KPM Motorsport
Hi
1) The 6mm spacers are slotted meaning the 4 x subframe bolts can be loosened approx 10mm and the spacers slipped in. Retension . 5 mins Done!
2) Sorry, all the sandwich plates are manufactured in bulk with the streetfighter signature included.
If i can answer any further question for you, please feel free to ask.
David
Western Australia
Old 03-03-2019, 04:52 PM   #15
ScottD
Hi David
I have a Falcon FGX XR8 Sprint and want to add the inter cooler kit with riser plate. What changes need to be made to make this fit under the bonnet. I donít want to loose the Sprint plate on the top of the engine as at any point I want to be able to switch it back to original.
Hope I hear from you soo thanks.
Scott
ScottD is offline   Reply With Quote Multi-Quote with this Post
Thread Tools
Display Modes
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
