Old 15-04-2006, 02:48 AM   #31
BlackLS
Posts: n/a
Originally Posted by kcbworth
If i can get a hold of the Sony 6 stack that comes with the XR5T does anyone know if it will be able to hook up to the Aux input in the glovebox?
Hi mate,
I'm pretty sure on this. It apparently also has MP3 disc support. But don't quote me.
Cheers,
Chris
Old 15-04-2006, 01:04 PM   #32
#Russ#Es#
Hello Koni's!
#Russ#Es#'s Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: This member has made a few valuable contributions to the Forum in the Focus section, seems to know exactly what he is talking about with his posts, which are helpful and concise.
Originally Posted by BlackLS
LS Focus: Rear doors are almost certainly 6.5", mounted on a platic pod (or the pod is part of the speaker construction. These are Mid-Low drivers.
Front foor: Another mid-low driver, 6.5". Up near the door pillars are tweeters.
There your standard stock cardboard speakers, and if you were to upgrade the sound, id choose to do replace the speakers. Get some nice front splits and 6.5" woofers for the rear if you can find one. If you have audiophiones constantly in the back, perhaps think about splits in the back as well (on the pillar face the tweeters towards the back seat and not into your ear.) These are my next mods.
Upgrading your stereo, Zetec20 has mentioned to me the new xr5 willl be using the Sony 6 stack, so check these out first. if you want LCD, go onot ebay and search "Lilliput touchscreen". You'll also need a carputer so checkout mp3car.com as well (theres tutorials on how to mould a screen into your dash.
If you just want to use a DVD/MP3 head unit and the screen, mount the head unit down near the ciggarette lighter(power supply) in that area. (youll need to cut)
Thanks for that. I'm planning on using Boston Acoutics speakers all round (possibly splits up front). I may have to sound deaden a bit though, I imagine the more powerful Boston's could cause some rattles further down the track!!
In regards to the factory audio controls vs aftermarket headunit remote: I was thinking of either buying the Sony (factory) premium headunit and using the factory controls, or buying a aftermarket h/u with a facia.
If I went the second option, I would try to buy the steering column trim from the CL Focus (that has no steering column audio controls) and fit that to my LX so it looks factory.
#Russ#Es# is offline   Reply With Quote Multi-Quote with this Post
