30-04-2007, 12:13 AM | #1 | ||
FTF Club Moderator
I have a problem with my wipers, they don't work. The very rare time that Sydney gets continous amounts of rain they stop. Lucky I have a bottle of rainx. I have tried a few things.
1. Got a new combination switch. 2. Tested the earth. 3. Tested the wiper motor. 4. Tested the fuse. None of the above fixed the problem. I got a test light out and tested the connection going to the wiper motor under the plastic cover at the base of the windscreen. There is no power getting to it.So somewhere along the wires some thing is not working how it should. What could that be? Can anyone help. Cheers Chief
Albert Einstein: Es ist schwieriger, eine vorgefaßte Meinung zu zertrümmern als ein Atom. (It is more difficult to alter a preconception than split an atom) Falcon Tickford FPV (FTF) Car Club of NSW Fords in the Park 2010 I use and recommend Stingray Car Security. http://www.stingraycar.com.au/ |
30-04-2007, 12:29 AM | #2 | ||
Karasu
My guess would be that you have a crook wiper motor relay, it'd be in the fuse box, try swapping it out for the A/C relay and see if it works. If you've changed the combination switch and checked the fuse and you have no power to the motor; except for a break or short in the wires (not impossible but unlikely) it's the only other thing it can be.
30-04-2007, 12:31 AM | #3 | ||
FTF Club Moderator
I haven't tried the realy yet. I will go out and have a look. Like you said I highly doubt it would be a break / short in the wires.
30-04-2007, 12:38 AM | #4 | ||
the wipers are controled through the BEM so it could be that but i'd treat that as a last resort as it is a costly item and you need to get the smartlock or smartshield to relearn if you replace it
30-04-2007, 12:42 AM | #5 | ||
FTF Club Moderator
I just looked the through the manual to the fuse and relay diagrams (page 139) and can not see the relay for wipers. When there is dead silence you can hear clicking in the BEM when you turn the wipers on and off. I unscrewed the BEM and held it in my hand under the dash.
30-04-2007, 12:43 AM | #6 | ||
Karasu
Yeaht that's true but it's wiper speeds/intermitant timings that are controlled plus if the BEM module went down I'd expect to see faults in the smartlock, courtesy lighting and other connected systems, when these things fail it's seldom only one system that's effected.
30-04-2007, 12:46 AM | #7 | ||
Karasu
That doesn't sound good, can you determine which wire is the wiper power out connection and see if you have power on that line?
30-04-2007, 12:51 AM | #8 | ||
FTF Club Moderator
I do not know which wire is the power wire, but I got a test light and tested all 5 pins in the connection to the wiper motor, the test light did not light up.
Being a wagon I can use the rear wiper and still squirt water onto the windscreen but can not use the wipers.
30-04-2007, 01:05 AM | #9 | ||
Karasu
we talking high or low series?
Looking at the scematics for the BEM would appear your problem lies there, Rear wipe is still working you say so that rules out the combination switch, can't remember if there is a fusible link in the engine bay for the wipers be worth checking, the way I read the diagrams you still should have power to one pin of the wiper motor plug, have you checked to make sure you have power to both sides of the wiper fuse? |
30-04-2007, 01:18 AM | #10 | ||
FTF Club Moderator
It would be low series. My wagon is a forte. There is power to both sides of the wiper fuse. I have checked the engine bay fuse box and there is no mention of a wiper fuse in there. May need to take it to an auto electriction to check the BEM. Maybe a fault code would of been stored.
30-04-2007, 01:34 AM | #11 | ||
Karasu
according to the diagrams on this site the dark blue/ yellow wire on the wiper motor plug should be live +12v looking at this I am inclined to think the wiper park function is to blame (black/pink wire) this provides the park signal from the BEM, first I would checking that you have power through the blue /yellow if there is nothing there then your problem lies elsewhere... sorry mate best I can do at this time of night, will have another look at it after a few hours of Zzzzzzz's
30-04-2007, 01:35 AM | #12 | ||
FTF Club Moderator
I dont blame you for wanting some Zzzzz's. I am off to bed. Thank you very much for your help.
30-04-2007, 11:47 AM | #13 | ||
Chief - I sued to get an intermittant thing where the wipers (all of them) wouldn't work. It kept blowing the fuse in the fuse panel. What used to get mine working was jiggling the wires that feed through the firewall area to the wiper motor (right up near the cowling near the bonnet (you do this with the bonnet up), and then I'd replace the fuse, and it wouldn't blow. I now seem to have cured it, as it hasn't happened in a while - though I don't know how I cured it!
It's just a matter of checking the wiring all the way back - if you aren't getting power at the motor wiring, then change the fuse (don't just check it).
30-04-2007, 11:13 PM | #14 | ||
FTF Club Moderator
Thanks JC, it was a loose connection. Stav gave me a call and dropped in at work today, pulled out the fuse panel and started playing with the connections. He found the problem within 10 minutes.
Stav saw this thread, realised I needed help, gave me a call, within 45 minutes was at my work, fixed the problems in 10 minutes and had a good yarn in the process. That is customer service.
01-05-2007, 12:22 AM | #15 | |||
You have to wonder how these cars develop loose connections though, don't you? Imagine something with ESC and EBD and whatnot getting a loose connection right when you need it!
01-05-2007, 12:54 AM | #16 | ||
glad it was just wiring the bcm would have been an expensive exercise and a pain to get the learning done
01-05-2007, 08:08 AM | #17 | ||
Smile
Heheh funny stuff that. checked the fuses..ok. Turned on the switch..heard the bcm click with intermittent wipers.Pulled down the fuse box and played witht the wires..bingo !! The wires touched and the wipers started working.Being under the dash i didnt hear or see anything.Lucky Chief was around because he saw them.Otherwise I wouldnt have noticed it..Need a holiday I think..hehe
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again |
31-12-2016, 02:12 AM | #18 | ||
Hi, I know this is an old thread but I'm hoping you guys can answer me this.......
AU wipers are working but barely moving up & down the windscreen, would this be as simple as the motor has **** itself? Or could it be something else? |
31-12-2016, 10:46 AM | #19 | ||
Au Falcon = Mr Reliable
Hi Scott, ask Bill he may be able to advise you. Good luck!
http://www.fordforums.com.au/showthread.php?t=11450623 cheers, Maka
Ford AU Series Magazine Scans Here - www.fordforums.com.au/photos/index.php?cat=2792 Proud owner of a optioned keeper S1 Tickford Falcon AU XR6 VCT - "it's actually a better-balanced car than the XR8, goes almost as hard and uses about two-thirds of the fuel" (Drive.com 2007) Last edited by Maka; 31-12-2016 at 10:51 AM. |
01-01-2017, 06:21 PM | #20 | ||
Hello Scott,
mine were working but on the intermittent cycle in between wipes they would park and then rise up 60- 80 mm before stopping. No other faults, just one of those little annoying things. I ended up getting a whole wiper motor arm assembly from a low km Fairmont and trying that which worked a treat. cheers Bill
AUII XR6 VCT ute 20 years and still going strong! |
01-01-2017, 07:34 PM | #21 | ||
^^^^^^^They do have a coverplate that you can take off that has the metal leaf brushes - sometimes you'll get one that breaks off and upsets motor operation.
Possibly, but the wiper linkage pivots might be gummed up as well. What you can do is remove the plastic cowls, undo the wiper motor mounts to get to the linkage - ball connection, lever off with a screwdriver. Operate the motor unloaded - should only take a few seconds for a rotation. Move the linkage by hand to check if it's free moving. |
09-01-2017, 05:45 PM | #22 | ||
Thanks guys, just got one from the wreckers will put it in soon
