Old 18-02-2015, 03:07 PM   #1
BlackDalek
Default spark plug firing order for Telstar 2.0L
Trying to figure out if the plugs are attached in the correct order.
I can't find a photo anywhere of the correct order.
I can find references on the internet to 1-3-4-2.
I tried connecting them as 1-3-4-2, but perhaps I did it wrong as engine is shaking and making a lot of odd noise.
Attached if a photo of order I used, based on the sequence 1-3-4-2
BlackDalek is offline   Reply With Quote Multi-Quote with this Post
Old 18-02-2015, 03:30 PM   #2
BlackDalek
Default Re: spark plug firing order for Telstar 2.0L
wait a minute.... should 1-3-4-2 be the order of the plugs on the cap (yellow numbers)
And the plugs on the actual engine (red numbers) be 1-2-3-4 ?
Is that where I went wrong?
Old 18-02-2015, 04:12 PM   #3
STINKY NINJA
1342 on the dissy so you just need to know where number 1 is on the dissy and the rotation of the dissy to work it out from there,numbers on the motor should read 1234 left to right,should always mark numbers when removing/replacing leads.
STINKY NINJA is offline   Reply With Quote Multi-Quote with this Post
Old 18-02-2015, 04:25 PM   #4
Road Games
Road Games's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Replacement.
Spot on matey .. gotta love cars eh
Road Games is offline   Reply With Quote Multi-Quote with this Post
Old 18-02-2015, 08:37 PM   #5
BlackDalek
never mind... found the firing order in the repair manual. Got it connected properly this time and it runs smoothly.
