Old 28-08-2021, 12:22 AM   #1
Ben
Ben's Avatar
Default AU xr8 hood clearance
Anyone know if a 1 inch spacer is to much so I can run taller rocker covers to fit stud mounts with an RPM2 on a efi windsor. Trickflow also do a 3/8 phenolic spacer but unsure if this will be enough.
2001 AU2 220 XR8 - Build thread
Ben is offline   Reply With Quote Multi-Quote with this Post
Old 28-08-2021, 02:34 AM   #2
CFOUR
The Destroyer
CFOUR's Avatar
Default Re: AU xr8 hood clearance
yeah the tps will hit the bonnet insulation with a 1"one an if you loose/have-a-worn-out a engine mount it will dent the bonnet in that spot, 1/2" fits. heres one, sorry for the ebay link https://www.ebay.com.au/itm/12MM-MAN...-/401415924165
Toy- Blown XR8 Ute. Black on black
"Front-drive cars are for children"
CFOUR is offline   Reply With Quote Multi-Quote with this Post
Old 28-08-2021, 10:30 AM   #3
Ben
Ben's Avatar
Thought I would add some more context.
Looking at options for heads/cam at the moment. Looking at the AFR 165 pedestal mount but just figuring out what would need to be done to go with a stud mount 11r 190 heads combo.
Main issue seems to be clearance issues with stud mounts.
Old 28-08-2021, 11:04 AM   #4
73 4V XB
Frankenford pilot
73 4V XB's Avatar
A little trick I learned years ago is make some dough, flower and water, or if you have blue tack or plasticine on hand. Roll it into a a length, cut it to the required height, 1” for a 1” spacer and put it on the highest point and close the bonnet. It will compress to show exactly how much clearance you have and won’t damage a thing.
Cheers Bretto
73 XB GT
Last of the Big Ports
73 4V XB is online now   Reply With Quote Multi-Quote with this Post
Old 28-08-2021, 05:07 PM   #5
tbro4123
Called Playdough!!!
tbro4123 is offline   Reply With Quote Multi-Quote with this Post
Old 30-08-2021, 02:43 PM   #6
Bossxr8
Peter Car
Bossxr8's Avatar
I've run the half inch spacer on an NL and the tps rubbed the bonnet insulation mat. But i've now got 11R heads and a Trickflow R manifold. Running the trickflow rocker covers, which are a medium height rocker cover, and there is no need for an intake spacer.
Nearly all the aftermarket rocker covers are too tall, but the trick flow ones are a nice height to clear roller rockers, but not too tall to touch the intake manifold.
