Old 14-04-2021, 04:28 PM   #1
Blackknight11
Post Fuel gauge not working
A few weeks ago I thought something was going on with the fuel gauge, so this is how it started.just came back from a long trip, only had 50kms left in tank, but the gauge was telling me that it was three quarters full. Filled the tank with diesel, full 75lts,range 780kms, it was reducing as I was driving as normal , but I didn't have the trip meter on, when it got to 610km range the needle fell from three quarters to nearly empty, after each start it was 60km,20km, 10km when it got to 5km fuel system warning ⚠ flash on, I knew that the tank wasn't empty, but just to safe and a hassle I filled it up again, only took approx 35lts, now the gauge is on empty and I have zero range, but it still starts and goes. I had an electric wire burn out on the blower fan, under the dash. Last week, but not sure if it got anything to do with this problem. I welcome your comments, and any recommendations expect for a Ford dealership for repairs as this will be ching ching $$.
Blackknight11 is offline   Reply With Quote Multi-Quote with this Post
Old 14-04-2021, 04:32 PM   #2
lincolnland
Default Re: Fuel gauge not working
Disconnect the battery overnight. Let it reset. Replace sender in tank.
Sent from my SM-G950F using Tapatalk
lincolnland is offline   Reply With Quote Multi-Quote with this Post
Old 14-04-2021, 05:22 PM   #3
Blackknight11
Ok thanks I will try disconnecting the battery and let you know what happens.
Old 14-04-2021, 09:03 PM   #4
Blackknight11
As I have close to about 500kms in the tank it will be a week or so before I can think about the sender. Cheers
Old 15-04-2021, 11:13 AM   #5
Blackknight11
Unhappy Re: Fuel gauge not working
Well I disconnected the battery last night.reconnected it the next morning,gauge only moved up a friction, 90kms range.
Old 17-04-2021, 09:38 PM   #6
xrplease
My FG had a bent fuel sender. After running out of fuel a few times thinking each time it still had fuel according to the gauge I replaced the sender.
xrplease is offline   Reply With Quote Multi-Quote with this Post
