04-02-2006, 06:39 PM | #1 | ||
not here much anymore
An LR Focus with the optional Ford bodykit fitted - the rear bar in particular. Seeing as mine will require modification to fit around my exhaust, I need to see some pics to work out what the best way to cut it will be. I think probably fit the skirt to the bar then cut to suit will be the go?
Pics would be appreciated.
RAM 1500
04-02-2006, 08:42 PM | #2 | ||
Check out this Autospeed article, it has some good pics of the rear bar.
http://autospeed.drive.com.au/cms/A_1580/article.html |
05-02-2006, 11:06 PM | #3 | ||
thanks for that, looks like the rear bumper skirt actually sits up on the bar a bit. should hopefully clear where i need to cut for the exhaust tip.
RAM 1500
