Old 22-09-2019, 06:01 PM   #1
Edxr6
Default AU Series 3 XR8, rear brake lights
Guys,
Can someone tell me which fuse is the Brake Lights, currently both brake lights and the centre rear screen brake light not working. I will try the easy option first. Or globes are OK. AU Series 3 XR8.
Edxr6 is offline   Reply With Quote Multi-Quote with this Post
Old 22-09-2019, 06:50 PM   #2
Beastie
The Terrain Tamer
Beastie's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: Catering services for a bunch of layabouts and for being an all-round good guy whose sense of community goes above and beyond.
Default Re: AU Series 3 XR8, rear brake lights
Have a look here.
https://www.fordforums.com.au/vbport...articleid=1582
Looks like No. 5 is the place to start.
Current Ride : A Ford owned D3...
Beastie is offline   Reply With Quote Multi-Quote with this Post
Old 22-09-2019, 09:01 PM   #3
Edxr6
Originally Posted by Beastie View Post
Have a look here.
Changed the fuse still not working? Any options.
Regards
Old 22-09-2019, 09:41 PM   #4
Beastie
The Terrain Tamer
Beastie's Avatar
Do you have a towbar?
Sometimes the wiring on the socket for the trailer plug can create problems?
Old 22-09-2019, 09:45 PM   #5
foxtrot3
foxtrot3's Avatar
Hi. Use a test light to check each side of the switch on the brake pedal, its a common failure point. Cheers MD
HI
I'M MICHAEL
foxtrot3 is offline   Reply With Quote Multi-Quote with this Post
Old 22-09-2019, 10:05 PM   #6
Edxr6
Yes I do, I will check that tomorrow. Now that I have looked into further, it may be the brake like switch, I will try the ED switch on the AU, I think they are all interchangeable.
Old 22-09-2019, 10:07 PM   #7
Edxr6
I think your on the money foxtrot3, I will give it a go tomorrow.
Old 23-09-2019, 04:18 PM   #8
falcongt4me
TSCoA member Qld
falcongt4me's Avatar
If your car is fitted with a boot mounted spoiler check the wiring harness that runs along the boot hinge as this is a common pinch point where the wires break. This happened to me
Cheers,
Martin Mac.
2002 AUIII TS50 Liquid Silver #206 (ex NZ)
T-Series Club of Australia member; QLD
falcongt4me is offline   Reply With Quote Multi-Quote with this Post
Old 23-09-2019, 05:44 PM   #9
Edxr6
Cheers,
I will check that now.
Regards
Old 23-09-2019, 06:51 PM   #10
Edxr6
Originally Posted by Edxr6 View Post
Cheers,
Regards
Wiring in the boot all good, off to Bursons tomorrow to purchase the Brake light switch.
Regards
Old 24-09-2019, 06:54 PM   #11
Edxr6
Regards
Guys,
What’s the go with these brake light switches once you take them off it’s like they won’t go back on, what’s the trick?
Old 24-09-2019, 09:28 PM   #12
Edxr6
Guys,
Worked it out, I had to pop off the brake booster leaver, put the sleeve through and then the switch. Bingo, it was the switch that was faulty, working fine. $20.00 from Bursons, good comparison to Original.
Thanks fellas
