Old 26-12-2012, 10:26 PM   #1
Simple6
Simple6's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Tech article on rear bushes.
Default Looking at a KN or KQ
Hey Guys,
Girlfriend likes the look of KN & KQ Lasers and wants to look at buying one in the near future. Only thing is though I have no idea what to look for with Lasers or anything about them really! Give me a Falcon any day....I've been through plenty!
So are there any issues with them I should look for when checking them out? I read on FordLaser.com that they have timing belts so that would need to changed every 100k or so I assume, big/expensive job or can do at home? I also read that they're a non-interference motor, but the person who said that did not specify whether it was the 1.6, 1.8 or 2.0.
What are we looking for?
1976 XB Falcon 500 Wagon - BUILD THREAD
Sherwood Green | 3spd/250CI | Running Whitewalls on a 2.5" Drop
Simple6 is offline   Reply With Quote Multi-Quote with this Post
Old 27-12-2012, 08:22 AM   #2
russellw
Chairman & Administrator
russellw's Avatar
Default Re: Looking at a KN or KQ
I wouldn't be bothering with anything other than the 2.0 - none of them are bad engines but they smaller ones are noticeably lacking in power.
Timing belts are something you could manage if reasonably competent.
Otherwise, they generally have a good reputation for reliability, are reasonably plentiful and parts are easy to come by.
Russ
Observatio Facta Rotae
Old 27-12-2012, 10:54 AM   #3
Russ
Russ's Avatar
Contributor: For members who make a contribution worthy of recognition. - Issue reason: Very helpful and gracious with photoshop work to help others..
I'm pretty sure the only Laser with the 2.0 motor was the SR2 ? If so they are a nice little car, very sporty looking and go quite well. I would however be careful when choosing that it has had regular log book servicing because the engines can be quite expensive to repair. I went through this on a 2001 model I purchased for my son a few years back, it had good service history but there was a period of about 6 - 12 months and 20,000 k's where there was no service history recorded and unfortunately for us after having a full service done we discovered later that the engine had obviously been doctored to cover up a valve stem seal issue. Quotes ranged from $2,000 to $4,500 to repair I traded it in a couple of days later and actually managed to get the money back on it My eldest son also had a Laser for many years, it was a KH Ghia hatch, 1.8i 5 speed manual, air, steer, 4 wheel discs etc.... We dropped in a K and N panel filter and had a sports muffler fitted and it went like a little rocket. It never gave him any real trouble and apart from the usual serviceable items such as brakes, oil, filters and the like it had a new clutch at around 170,000 k's and we had to change the idle control valve at some stage too due to fluctuation when idling, I managed to pick up another complete throttle body unit and replaced the whole thing ($30 from the wreckers)
Russ is offline   Reply With Quote Multi-Quote with this Post
Old 27-12-2012, 07:03 PM   #4
Simple6
Simple6's Avatar
Cheers guys!
Doesn't sound like there is too much to worry about then.
Yeah the SR2 was the only one with the 2.0 so I don't know if we'll be able to find the right car with that motor because they aren't as common but it'll be the 1.8 at an absolute minimum.
Old 27-12-2012, 10:16 PM   #5
Russ
Russ's Avatar
Originally Posted by Simple6 View Post
Cheers guys!
Happy hunting
Old 29-12-2012, 04:13 PM   #6
79FordEsky
79FordEsky's Avatar
What about telestar 2.0 conversion on a laser?
My Ride: -
My Survivor 1 owner XC Wagon
Check it Out
79FordEsky is offline   Reply With Quote Multi-Quote with this Post
