Old 18-02-2021, 01:32 PM   #1
mlmho5
Default P0700, P1719 codes on a MC 2L diesel
I think these are transmission codes
mlmho5 is offline   Reply With Quote Multi-Quote with this Post
Old 18-02-2021, 06:04 PM   #2
GTLEGEND
Default Re: P0700, P1719 codes on a MC 2L diesel
Check for a loose earth on the LH chassis rail just under the air cleaner. If you can rotate the eyelet, then its a possibility its a bad earth and can cause the two codes you are referring to.
Could also be attributed to EGR and MAP sensor issues.
Old 18-02-2021, 11:43 PM   #3
mlmho5
I will start by pulling out the egg valve assembly. Thanks for your help.
Old 19-02-2021, 04:49 PM   #4
mlmho5
Blanked off EGR and took it for a 50km run. No codes. New EGR with cooler $724 from Ford!
