EXR-699
Hi All,
Looking for recommendations or Ideas. I have purchased a new cluster for the XR8, and the odometer is too low. Does anyone know of a hack or software that can do it, or does anyone know someone in the sydney area that can do the adjustment Cheers
Go Pedal = Fun Pedal AU XR8 Tickford 200kw Visit my Blog lovemyfalc.blogspot.com RIP - AU1 1999 XR6 VCT, Forever in my heart. |
There are a few people that do it who advertise on ebay.
The going price seems to be around $100 from what I have seen. There are also a number of tools that you can buy to reset odometers but AFAIK all the tools that you can buy for under around $2,000 require that you need to pull apart the cluster, un-solder & remove the chip to program, then re-solder & replace it. |
Should be able to swap over the Eprom chip. See ' Swapping odometer readings' http://www.fordmods.com/ford-technic...ter-upgrade-d4
There's a pic of the chip on an EF/EL falcon board here http://www.fordmods.com/ford-technic...nstruments-d14 I've done a few - they are tiny, around 5mm, so they need magnification. An electronics repair shop should be able to do it for you. |
