Go Back   Australian Ford Forums > Club and Speciality Forums > Ford Car Clubs > Perth Falcons > General Discussion
Old 08-01-2008, 12:28 AM   #1
AUFairmont
HSV, I just ate one
Default Whoop *** Wednesday 09/01/08
Whos going to Whoop *** Wednesday this Wednesday (09/01/08) ?
I will be there in my BF XR8 (DVSLYQUIK) Hopefully making a 13.3 pass
AUFairmont is offline   Reply With Quote Multi-Quote with this Post
Old 08-01-2008, 09:21 PM   #2
Jimmysxr
JimmysAUXR6
Jimmysxr's Avatar
yeah i might go give mine a blast just see what time i finish work
Jimmysxr is offline   Reply With Quote Multi-Quote with this Post
Old 08-01-2008, 10:45 PM   #3
AUFairmont
HSV, I just ate one
I took the day off work
So can get it serviced in morning and get it washed around lunch time then lose a little weight like the spare wheel and some i got in boot and back seat and be ready for hunting more 13.3's
Old 10-01-2008, 02:24 AM   #4
AUFairmont
HSV, I just ate one
OMG Today sucked *** !!!! think it was the warmer temp and very high humidity ! i couldnt get lower then a 13.6 by memory GRRRRR
Was expecting at least 1 run at 13.3 :(
Old 10-01-2008, 03:36 AM   #5
XR8-260
I noticed in another thread that you have Dunlop SP9000 tyres. I was just wondering whether they are 235s or 245s? Also, what tyre pressures did you use?
I have trouble getting traction at the track in my XR8 so I'm a little curious about your setup.
Cheers.
XR8-260 is offline   Reply With Quote Multi-Quote with this Post
Old 10-01-2008, 03:22 PM   #6
BENXR6T
BENXR6T's Avatar
i'l give you a tip - dont lower the psi on low profile tires
it does next to nothing. a low profile tire will peform at its best when at the reccomended psi
05 BA II Pursuit Ute # 147 in RAPID
20" incubus rims
6 speed manual
BLUEPOWER CAI
twin 2.5" catback
more to come
BENXR6T is offline   Reply With Quote Multi-Quote with this Post
Old 10-01-2008, 03:24 PM   #7
XR8-260
Ah, thanks for that. What brand tyres are you using for your turbo?
Old 11-01-2008, 12:43 AM   #8
AUFairmont
HSV, I just ate one
I used to have Dunlop SP9000's but got new tyres on the back.....
I belive lowering the pressure in my tyres does help but it is fairly over rated it doesnt make a huge difference its only slightly better or so i have found....
When i was there couple months ago i was running with normal pressure, getting constant 13.6's then dropped to 19psi and started getting constant 13.5's
Was about 0.06 second difference i was averaging between standard pressure to dropping the pressure to 19psi.... so not huge but it is something. its that small of a benefit it probably not worth the extra damage you do to your tyres and iv been told it also puts more strain on your driveline.....
So yes 3 would be right in saying theres no point, but if your after that tiny drop off your time then id say give it a go....
Im half ****ed writting this so im sorry if it doesnt make sense lol :P
Old 11-01-2008, 01:07 AM   #9
XR8-260
What tyres do you now have? I've got some crappy 235/45 tyres so I'm looking for something that will give more traction. I don't really want to get drag tyres though.
