Old 07-08-2023, 07:28 PM   #1
Loris
Focus & Territory TDCi
Default 2007 LT Focus tdci 2.0 P2566 error
Hi all, have engine light on with P2566 Turbocharger boost control position sensor circuit intermittent.
Anyone had this happen before and know of a fix or replacement part number?
Is this the sensor on the turbo housing accessible from under car?
Im wanting to inspect the part to see if maybe a wire has been damaged and take it off the turbo to see if the position sensor is stuck/sticking.
Would be grateful if anyone has info on this issue?
Loris is offline   Reply With Quote Multi-Quote with this Post
Old 08-08-2023, 03:19 PM   #2
russellw
russellw's Avatar
Default Re: 2007 LT Focus tdci 2.0 P2566 error
You can start by having a look in the WSM (our tech portal) as it shows the location of the sensor and identifies some troubleshooting steps you can follow.
Old 23-08-2023, 10:57 AM   #3
Loris
Thanks Russell, I found the sensor in the workshop manual for my car.
Just to update the thread:
I found this video which helped me diagnose the issue - https://youtu.be/YZWvEakfElg?t=778
On the weekend I removed the sensor and although the sensor didn't seem stuck or sticking I pushed it in and out a few times to ensure it was freed up. Gave it a bit of clean and then reinstalled it.
Cleared the code and its been 3 days of driving and the code\engine light hasn't returned.
