Go Back   Australian Ford Forums > Club and Speciality Forums > Ford Car Clubs > XR6 & XR8 Club of Queensland
Old 04-02-2017, 01:58 AM   #1
Tedperry
Default AU XR8 Loose Fan belt sound
Sometimes when weather is cold, I start up and it sounds like a loud loose fanbelt. I have changed all belts couple of times, with no luck. This sound last for about 3 min and stops when car heated up. Mechanics have n't solved it.
****ed off 'cos XR8 s should never sound like that.
Can anybody help with advice? It would be greatly appreciated.
Ted
Tedperry is offline   Reply With Quote Multi-Quote with this Post
Old 04-02-2017, 10:02 AM   #2
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
Default Re: AU XR8 Loose Fan belt sound
Pulleys? Try some soem talcom powder
UK
Old 04-02-2017, 11:42 AM   #3
Could also be the water pump or alternator bearings. But take the serpentine belt off (when the engine is cold) and spin each pulley in the system and see if there is any roughness or noise. Also check the belt isn't glazed (shiny on the running ribbed side surface).
Old 04-02-2017, 12:10 PM   #4
Uncle_Ken
Uncle_Ken's Avatar
I agree
UK
Old 26-12-2017, 08:56 AM   #5
andybro
She'll be the cam synchroniser. Replacement is the best option, although you can take them apart and lubricate the bearing
andybro is offline   Reply With Quote Multi-Quote with this Post
Old 26-12-2017, 12:04 PM   #6
Tassie f100
Try tipping a cup of water on the belt when first starting up.If the problem is an old hard belt the noise will disappear for a few seconds.If water doesn,t make any difference the problem is mechanical
Tassie f100 is online now   Reply With Quote Multi-Quote with this Post
Thread Tools
Display Modes
