21-11-2017, 08:37 PM | #1 | ||
Call me dirt... Joe Dirt
Silly question maybe, but I'm not about to join a plumbers forum to ask...
When applying teflon thread tape, how many times are you supposed to wrap it around the thread? I reckon I always put on way too much, but don't know when is enough. I'm talking just typical domestic plumbing here, kitchen taps etc.
2007 BFII FPV Cobra Ute|Boss 302|6M|#23/100 Mods so far: Billet Products Shifter|X-Force Exhaust|Herrod Oil Breathers|Whiteline Sway Bar|Tein SuperStreets|Kings FOR-303SL Rear Springs|Melling Oil Pump|Mace Manifold Spacers|Powerbond Underdrives|Pacemaker Headers|Ballistic Cats|XFT Custom Tune @ 308.3rwkw|DBA T3 Rotors|Ferodo Pads|Goodridge Braided Lines Mods to come: 4.11 Diff Gears|Chromoly Tailshaft I use & recommend: Castrol|Motorcraft|Mainlube|Penrite Check Out My Build Thread |
21-11-2017, 08:39 PM | #2 | ||
I usually go about 6-8 times and I haven't had a leak yet. I'm not on mains pressure though - tanks with pumps.
21-11-2017, 11:10 PM | #3 | ||
PURSUIT 250
7. (Need 5 characters to post)
22-11-2017, 01:09 AM | #5 | ||
Always on clockwise.
3 users like this post: |
22-11-2017, 01:25 AM | #6 | ||
All Bran = Regular Member
In another life I used to sell/repair aircompressors.
Always 10 (or 11 or 9) for air pressure so I just continue the theme for water pressure. Possibly overkill but tape is cheap. Never had a leak and I've renovated a few bathrooms....
2 users like this post: |
22-11-2017, 09:10 AM | #7 | ||
Why would you even need thread seal on kitchen taps ?
If they are in wall (called wall stops) they have a jumper valve, a red body washer, and o rings on the spindle. |
22-11-2017, 09:16 AM | #8 | ||
3 or 4 wraps will do as the fittings are tapered anyway. Stretch it tight on the fitting as you wind it on.
2017 Mustang GT (Magnetic) |
22-11-2017, 09:52 AM | #9 | ||
PURSUIT 250
22-11-2017, 10:30 AM | #10 | ||
A never on compression fittings.
regards Blue |
22-11-2017, 10:41 AM | #11 | ||
22-11-2017, 03:43 PM | #12 | ||
Thread sealants such as joint compound (pipe dope or thread seal tape such as PTFE tape) are unnecessary on compression fitting threads, as it is not the thread that seals the joint but rather the compression of the ferrule between the nut and pipe. The use of tape will prevent required compression; use sealant "dope/paste" if you must. But if it need sealant on a compression fitting your either doing it wrong or using cheap junk compression fittings.
regards Blue |
