14-01-2008, 05:05 PM | #1 | ||
i hav a 80 escort sport 1600 need to know what i need to do to put a 5 speed cortina gearbox in to it? any help would be appreciated.
14-01-2008, 07:49 PM | #2 | ||
i heard that the shifter will be a bit further back, but the bell housing matches the engine. not sure about transmission mount.
14-01-2008, 09:38 PM | #3 | ||
eskyman
im pretty sure that your escort has a manual gearbox tunnel you will need to do some cutting and welding to fit it in. 5 speeds fit well into an auto tunnel.
who says kents cant be quick |
15-01-2008, 05:59 PM | #4 | ||
thanks for yor help
15-01-2008, 10:55 PM | #5 | ||
I didnt think the cortina came out with a 5 speed?
New engine on the way : Weisco Pistons, Total Seal rings, Crower rods, BIG lumpy stick, TO4E with back cut exhaust wheel 1.0 rear housing 30psi!!, major head modification! Bring on the 1/4 mile : |
16-01-2008, 09:06 AM | #6 | |||
I think he means a Sierra 5-speed. Gear lever sits a few inches further back and gearbox mounts need modification. Not exactly rocket-science. |
16-01-2008, 08:57 PM | #7 | ||
out of curiosity what is the best 5-speed for the mkII esky? is it the one out the sierra?
Don't P*ss Me Off, I'm Running Out Of Places To Hide The Bodies!!! : |
16-01-2008, 09:15 PM | #8 | ||
Depends what you mean by "best". Some common upgrades include a celica/supra 5 speed box which have higher gear ratios than the sierra 5-speed and escort 4-speed, but you are required to get a different bellhousing for it to match the escort. Otherwise the sierra 5-speed is just a escort/cortina 4-speed with an over-drive ( or an extra gear ) as the first 4 gears are the same ratio. However many people prefer the 4speed as it is much stronger than the 5 speed and are much easier and cheaper to source.
hope this helps. please correct me if im wrong guys |
18-01-2008, 11:17 PM | #9 | ||
ok thanks!!!
