23-12-2016, 12:25 PM | #31 | ||
*barks incessantly
I would be amazed if this move was truly aimed at improving the environment. I think it is more likely that the mainstream media has been instructed to promote the secondary environmental benefits as loudly as possible to disguise the reality that this is primarily intended to earn the faceless shareholders of oil.co more substantial profits.
We are car enthusiasts and generally spend more on our cars than most other people, many of us already use premium fuels but there are some people out there that simply won't be able to afford the slight increase to purchase 95 RON. Removing the cheapest fuel type is sure to impact those who are living on a budget - as with most things, the impact may not be obvious in the short-run but will become obvious long-term. I am skeptical that this is really in the best interest of the general public. |
23-12-2016, 12:37 PM | #32 | |||
2 users like this post: |
23-12-2016, 01:39 PM | #33 | |||
Bathed In A Yellow Glow
Whether you believe climate change is a manmade process or a natural occurrence the evidence does appear to substantiate something nasty is happening and maybe it would be a good idea to try and address the situation before it’s beyond changing if that isn’t already the case. No we are not Europe but given Australia’s location on the planet, its topography and the fact we are near a dirty great big Antarctic ozone hole we are more likely to suffer its affects long before Europe does which means if we wish to maintain our lifestyle we have a very strong vested interest in slowing the process down. |
4 users like this post: |
06-01-2017, 12:05 PM | #34 | |||
Typical 91 RON stoich Air Fuel Ratio (AFR) is around 14.4, but for Ethanol this will be lower (around 14), so you will need to flow more fuel to maintain closed loop control. However the overall efficiency equation is not that simple and depends on engine & control system. As Ethanol has a higher octane rating you should be able to run more spark advance and depending on the compression ratio of the engine it may be able to take more advantage of this, but only if you have an aggressive individual cylinder knock control system to take advantage of this. Bottom line is that different vehicles will respond to Ethanol blends in different ways.
You can lead a troll to banter, but you cannot make him think. |
06-01-2017, 12:40 PM | #35 | ||
Australia will not have auto manufacturing after Oct this year, most vehicles are imported, and not designed to run on our crap 91 octane fuel. 95 is usually the minimum octane required, most engines run best on 95-98 octane fuel.
This is more than a discussion paper, the government is figuring out a way to spin the increase in overall fuel price to the consumer under the guise of a cleaner environment.
2021 BMW M550i in Black Sapphire Metallic.
11.52 @ 120mph stock |
07-01-2017, 09:23 AM | #36 | |||
Au Falcon = Mr Reliable
As much as ide like to support our sugarcane farmers, e10 for owners of older cars is not a worthwhile proposition. If they reformulate e10 to match or surpass 91 ron at the same price point they would be on a winner imo! cheers, Maka
Ford AU Series Magazine Scans Here - www.fordforums.com.au/photos/index.php?cat=2792 Proud owner of a optioned keeper S1 Tickford Falcon AU XR6 VCT - "it's actually a better-balanced car than the XR8, goes almost as hard and uses about two-thirds of the fuel" (Drive.com 2007) |
07-01-2017, 10:20 AM | #37 | |||
Experienced Member
I found my old FG XR ran ok on it but would chew through it. |
07-01-2017, 11:46 PM | #38 | ||
Luckily I don't even own an unleaded vehicle, just LPG and Diesel for me.
I'm sad to see that the fuel of the gods - LPG - is being slowly phased out and no one cares! Wheres the news article on LPG huh? |
08-01-2017, 04:26 PM | #39 | ||
I'm involved with 6 Viva Energy sites in Perth which have removed LPG. Several of these sites had their last LPG refill 4 months prior to the decommissioning, showing the low demand for the product.
08-01-2017, 10:33 PM | #40 | ||
Nothing wrong with ethanol. It supports local industry, is renewable, combustion is cleaner, and it's cheap! Whilst it's slightly less energy dense, hygroscopic and not compatible with pre 1980s fuel systems, the drawbacks are minor and only affect a very small percentage of motorists. The average naturally aspirated car is perfectly fine running it, and I'd be surprised if anyone could produce empirical data to show significantly poorer economy with a 10% blend.
~Internal combustion motor enthusiast~ |
08-01-2017, 10:40 PM | #41 | |||
Former BTIKD
09-01-2017, 01:43 AM | #42 | |||
09-01-2017, 02:53 AM | #43 | ||
I hope 95/ 98 isn't wiped out in the coming yrs..
10-01-2017, 09:44 PM | #44 | ||
Good article Mr Express.
Reading between the lines, I wonder if this is the "that's it" point for our ageing, small refineries. Something along the lines of: "Well, sorry it will cost too much. We're shutting it. You can get imported fuel, and if the ship is late, you'll be glad you bought that donkey we advised you to." |
11-01-2017, 12:00 AM | #45 | |||
No wonder it's disappearing.
www.bseries.com.au/mercurybullet 2016 Falcon XR8. Powered by the legend that is - David Winter. XC Cobra #181. 1985 Mack Superliner, CAT 3408, 24 speed Allison. |
11-01-2017, 01:38 AM | #46 | |||
Experienced Member
I had two cars on LPG in the 90's, that was enough for me, I will never touch LPG again for vehicles. |
11-01-2017, 08:59 AM | #47 | ||
So what happens to all small engines - mowers, whipper snippers, rotary hoes, water pumps... ??
11-01-2017, 10:14 AM | #48 | |||
i think ethanol as a by-product from dairy companies etc is probably viable ,dunno about growing crops specifically tho
Fgx xr8 winter white manual, gone but not forgotten 22 mitsubishi outlander XLS PHEV Au11 fairmont Ghia ported gt40p heads ,comp springs and locks Xe 264 cam,custom intake,pacemaker tri y headers 524nm torque 19 Triton GSXR manual |
11-01-2017, 10:17 AM | #49 | ||
Speaking to someone who works at BP Refinery Kwinana, the refinery is due for shutdown for 6 months for maintenance and upgrade. It will be the last time an upgrade will be done to the plant, it's not cost effective to refine fuel in Australia compared to importing it direct from Singapore.
I think the move away from 91 octane fuel is to get the market ready for a total import of all fuels into Australia, with no local refineries in the next 5-10 years.
3 users like this post: |
11-01-2017, 12:59 PM | #50 | ||
*barks incessantly
Very interesting Romulus. Thanks for the insight.
11-01-2017, 02:23 PM | #51 | |||
11-01-2017, 04:00 PM | #52 | ||
Experienced Member
11-01-2017, 04:29 PM | #53 | |||
11-01-2017, 05:53 PM | #54 | ||
11-01-2017, 08:24 PM | #55 | |||
So, hate to do this on a Ford forum, but VEII 3.0 & V8, VFMY14 all motors can run on E85 ethanol, 100% with a chip. The catch is they use the GM HFV6... but, in event of future fuel supply drying up, these will run if you know what to do to ensure a supply of 'liquid sunshine' (check regs). It won't be glamorous, but it will beat the donkey. Has anyone on the Forums taken a Ford I6 and ethanol converted/chipped it? |
11-01-2017, 09:09 PM | #56 | |||
IWCMOGTVM Club Supporter
Daniel |
11-01-2017, 10:08 PM | #57 | ||
11-01-2017, 10:15 PM | #58 | ||
Not all small engines will run properly on 98, especially at idle because of the slower burn rate of 98 compared to 91 fuel.
11-01-2017, 10:29 PM | #59 | |||
Boss 335
12-01-2017, 11:57 AM | #60 | ||
OK cheers for that MM Any idea where I can research these E85 I6Ts?
